Trouble loading wildcard cert
I have a working caddy config that gets a wildcard cert from LetsEncrypt. However, I now need this config to work in an environment that can’t talk to LetsEncrypt. So I’m changing it to load the wildcard cert.
Now caddy fails to load.
The only part I changed here was the tis load_files pare (at the very end of the caddy file).
What am I doing wrong?
{"level":"info","ts":1725031773.93382,"msg":"using config from file","file":"/config.yml"}
{"level":"info","ts":1725031773.9368916,"msg":"adapted config to JSON","adapter":"yaml"}
{"level":"info","ts":1725031773.9403188,"logger":"admin","msg":"admin endpoint started","address":"0.0.0.0:2019","enforce_origin":false,"origins":["//0.0.0.0:2019"]}
{"level":"warn","ts":1725031773.940331,"logger":"admin","msg":"admin endpoint on open interface; host checking disabled","address":"0.0.0.0:2019"}
{"level":"info","ts":1725031773.940989,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0015eed00"}
{"level":"info","ts":1725031773.9410005,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0015eed00"}
Error: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: loading certificate loader modules: module name 'load_files': decoding module config: tls.certificates.load_files: json: cannot unmarshal object into Go value of type caddytls.FileLoader
xcaddy to add some plugin. Then my own Dockerfile to put in an image.
The container is launched with Kubernetes.
Linux
apiVersion: v1
kind: Pod
metadata:
  labels:
    app: caddy
spec:
  restartPolicy: Always
  containers:
    - name: caddy
      image: ext-registry.tilia-inc.com/library/caddy:latest
        - containerPort: 443
          protocol: TCP
        - containerPort: 2019
          protocol: TCP
      volumeMounts:
        - name: certs
          mountPath: "/certs"
        - name: config-file
          mountPath: "/config.yml"
        - name: config-dir
          mountPath: "/config"
        - name: data-dir
          mountPath: "/data"
        - name: logs
          mountPath: "/access_logs"
      env:
        - name: XDG_CONFIG_HOME
          value: "/config"
        - name: XDG_DATA_HOME
          value: "/data"
        - name: AWS_REGION
          value: "us-west-2"
      securityContext:
        runAsUser: 1000
        runAsGroup: 1000
      command: ["caddy", "run", "--config", "/config.yml", "--adapter", "yaml"]
    - name: certs
      hostPath:
        path: /tmp/makeworld/certs/
        type: Directory
    - name: config-file
      hostPath:
        path: /workspaces/extraction-makeworld/configs/caddy/config.yml
        type: File
    - name: config-dir
      hostPath:
        path: /workspaces/extraction-makeworld/configs/caddy/caddy_data
        type: Directory
    - name: data-dir
      hostPath:
        type: Directory
    - name: logs
      hostPath:
        path: /workspaces/extraction-makeworld/logs
        type: Directory
apiVersion: v1
kind: Service
metadata:
spec:
  selector:
    app: caddy
    - protocol: TCP
      port: 443
      targetPort: 443
# Run the command caddy_debug to set this config after caddy has already started up
# You can also change `configs/caddy/config.yml` after start-up and
# run `docker restart extractionmakeworld_nginx_1` to reload the configuration.
logging:
  logs:
    default:
      level: INFO
      exclude:
        - http.log.access
    access:
      writer:
        output: file
        filename: /access_logs/caddy_access.log
      include:
        - http.log.access
admin:
  listen: 0.0.0.0:2019
apps:
  http:
    http_port: 8080
    https_port: 8443
    servers:
      srv0:
        trusted_proxies:
          source: "static"
          ranges:
            - 10.0.0.0/8
            - 172.16.0.0/12
        listen:
          - :8443
        logs: {}
        strict_sni_host: false
        routes:
          - match:
              - host:
                  - accounts-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        # The rewrite is needed to fix bad bdd tests
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                      - handler: reverse_proxy
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                                - '{http.request.remote}'
                        upstreams:
                          - dial: accounts-ops-api:80
            terminal: true
          - match:
              - host:
                  - fraud-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: fraud-ops-api:80
            terminal: true
          - match:
              - host:
                  - invoicing-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: invoicing-ops-api:80
            terminal: true
          - match:
              - host:
                  - payments-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: payments-ops-api:80
            terminal: true
          - match:
              - host:
                  - personas-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: personas-ops-api:80
            terminal: true
          - match:
              - host:
                  - pii-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: pii-ops-api:80
            terminal: true
          - match:
              - host:
                  - registration-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: registration-ops-api:80
            terminal: true
          - match:
              - host:
                  - wallets-ops-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: wallets-ops-api:80
            terminal: true
          - match:
              - host:
                  - balances.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        # Insert apigatway specific url elements
                      - handler: rewrite
                        uri: "/restapis/balancesid/test/_user_request_{http.request.uri}"
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: localstack:4566
            terminal: true
          - match:
              - host:
                  - notes.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri: "/restapis/notesid/test/_user_request_{http.request.uri}"
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
            terminal: true
          - match:
              - host:
                  - settings-lambda.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri: "/restapis/settingslambdaid/test/_user_request_{http.request.uri}"
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
            terminal: true
          - match:
              - host:
                  - settlement.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri: "/restapis/settlementid/test/_user_request_{http.request.uri}"
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
            terminal: true
          - match:
              - host:
                  - accounts-customer-sl.dev.tilia-inc.com
                  - accounts-customer.secondlife.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: accounts-customer-sl:80
            terminal: true
          - match:
              - host:
                  - kinesis-bouncelist-lambda.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: kinesis-bouncelist-lambda:80
            terminal: true
          - match:
              - host:
                  - fake-promise-integrator.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: fake-promise-integrator:80
            terminal: true
          - match:
              - host:
                  - fake-integrator-web.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: fake-integrator-web:80
            terminal: true
          - match:
              - host:
                  - testsamlidp.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: testsamlidp:8080
            "@id": testsaml
            terminal: true
          - match:
              - host:
                  - accounts-customer.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                    - handler: static_response
                      headers:
                          - /ui/
                      status_code: 301
                    match:
                      - path:
                        - /ui
                    terminal: true
                  - handle:
                      - handler: encode
                        encodings:
                          gzip: {}
                          zstd: {}
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: accounts-customer-web:3000
                    match:
                      - path:
                          - /ui/*
                          - /static/*
                    terminal: true
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: accounts-customer:80
                    terminal: true
            terminal: true
          - match:
              - host:
                  - email-bouncelist.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: email-bouncelist:80
            terminal: true
          - match:
              - host:
                  - fake-integrator2.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: fake-integrator2:80
            terminal: true
          - match:
              - host:
                  - registration-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: registration-api:80
            terminal: true
          - match:
              - host:
                  - fake-integrator.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: fake-integrator-web:3000
                    match:
                      - path:
                          - /static/*
                          - /ui/*
                    terminal: true
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: fake-integrator:80
                    terminal: true
            terminal: true
          - match:
              - host:
                  - kinesis-lambda.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: kinesis-lambda:80
            terminal: true
          - match:
              - host:
                  - email-service.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: email-service:80
            terminal: true
          - match:
              - host:
                  - invoicing-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: invoicing-api:80
            terminal: true
          - match:
              - host:
                  - lambda-server.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: lambda-server:80
            terminal: true
          - match:
              - host:
                  - proxy-service.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: proxy-service:80
            terminal: true
          - match:
              - host:
                  - elasticsearch.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - flush_interval: -1
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: elasticsearch:9200
            terminal: true
          - match:
              - host:
                  - accounts-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        # The rewrite is needed to fix bad bdd test: features/client/Client-UpdateSecretN.feature
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: accounts-api:80
            terminal: true
          - match:
              - host:
                  - payments-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: payments-api:80
            terminal: true
          - match:
              - host:
                  - personas-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: personas-api:80
            terminal: true
          - match:
              - host:
                  - wallets-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: rewrite
                        uri_substring:
                        - find: //
                          replace: /
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: wallets-api:80
            terminal: true
          - match:
              - host:
                  - localstack.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: localstack:8080
            terminal: true
          - match:
              - host:
                  - fraud-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: fraud-api:80
            terminal: true
          - match:
              - host:
                  - pub.dev.tilia-inc.com
            handle:
                headers:
                  request:
                    set:
                      X-Real-Ip:
                upstreams:
                  - dial: publisher-hosting:3000
            terminal: true
          - match:
              - host:
                  - soc.dev.tilia-inc.com
            handle:
                headers:
                  request:
                    set:
                      X-Real-Ip:
                upstreams:
                  - dial: socketio-server:8080
            terminal: true
          - match:
              - host:
                  - tools.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                  - match:
                      - path:
                    handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: tools-web:3000
                    terminal: true
          - match:
              - host:
                  - tools-web.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: tools-web:80
            terminal: true
          - match:
              - host:
                  - sl-login.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: sl-login:80
            terminal: true
          - match:
              - host:
                  - pii-api.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: pii-api:80
            terminal: true
          - match:
              - host:
                  - login.dev.tilia-inc.com
                  - login.sansar.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: login:80
            terminal: true
          - match:
              - host:
                  - nonce.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: nonce:80
            terminal: true
          - match:
              - host:
                  - auth.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        # The rewrite is needed because a bunch of bdds call https://{auth_service}//token
                      - handler: rewrite
                        path_regexp:
                        - find: /{2,}
                          replace: /
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: auth:80
            terminal: true
          - match:
              - host:
                  - caddytest.dev.tilia-inc.com
            handle:
                status_code: 200
                body: "Hello\nRequest Host: {http.request.host}\nTLS Server Name: {http.request.tls.server_name}\n"
            terminal: true
          - match:
              - host:
                  - www.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: subroute
                        routes:
                          - handle:
                              - BrowseTemplate: ""
                                EnableBrowse: false
                                EnableDelete: false
                                EnablePut: false
                                Hide: null
                                bucket: dev.tilia-inc.com
                                handler: s3proxy
                                region: us-west-2
            terminal: true
          - match:
              - host:
                  - web.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: widget:3000
                    match:
                      - path:
                          - /static/*
                          - /ui/*
                    terminal: true
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
            terminal: true
          - match:
              - host:
                  - widget.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: widget:3000
                    match:
                      - path:
                          - /static/*
                          - /ui/*
                    terminal: true
            terminal: true
          - match:
              - host:
                  - playwright.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: file_server
                        root: /playwright/playwright-report/
            terminal: true
          - match:
              - host:
                  - 'kibana.dev.tilia-inc.com'
            handle:
                status_code: 501
                body: "Kibana not running - run \"launch_kibana\"\n"
            "@id": kibana
            terminal: true
          - match:
              - host:
                  - stats.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: stats:8000
            terminal: true
          - match:
              - host:
                  - jpm-bin-lookup.dev.tilia-inc.com
            handle:
              - handler: subroute
                routes:
                  - handle:
                      - handler: headers
                        response:
                          set:
                            X-Frame-Options:
                              - SAMEORIGIN
                        headers:
                          request:
                            set:
                              X-Real-Ip:
                        upstreams:
                          - dial: jpm-bin-lookup:80
            terminal: true
          - match:
              - host:
                  - '*.dev.tilia-inc.com'
            handle:
                status_code: 501
                body: "Not wired up in proxy. See `configs/caddy/config.yml{,.tmpl}`.\nRequest Host: {http.request.host}\nTLS Server Name: {http.request.tls.server_name}\n"
            terminal: true
        automatic_https:
          disable: true
        tls_connection_policies:
          - match:
              sni:
                - discord-accounts-ops-api.dev.tilia-inc.com
                - graphql-ops-api.dev.tilia-inc.com
            client_authentication:
              ca:
                provider: "file"
                pem_files:
                  - /certs/ca.crt
              mode: verify_if_given
              # mode: require_and_verify
          - match:
              sni:
  tls:
    certificates:
      load_files:
        certificate: /certs/star.dev.tilia-inc.com.crt
        key: /certs/star.dev.tilia-inc.com.crt.key
I’m sure there is something wrong with my caddy config. I’ve narrowed the problem as it can happen if I just run validate:
caddy validate --config config.yml --adapter yaml
2024/08/30 16:54:27.225 INFO    using config from file  {"file": "config.yml"}
2024/08/30 16:54:27.228 INFO    adapted config to JSON  {"adapter": "yaml"}
2024/08/30 16:54:27.478 INFO    tls.cache.maintenance   started background certificate maintenance      {"cache": "0xc000b25680"}
2024/08/30 16:54:27.478 INFO    tls.cache.maintenance   stopped background certificate maintenance      {"cache": "0xc000b25680"}
Error: loading http app module: provision http: getting tls app: loading tls app module: provision tls: loading certificate loader modules: module name 'load_files': decoding module config: tls.certificates.load_files: json: cannot unmarshal object into Go value of type caddytls.FileLoader
But I don’t see what I did wrong in the config.yml? And that error message is so not helpful…
The load_files module takes an array of objects, not a plain object
See the docs here
