Translate nginx rules snippet in Caddyfile
I have a snippet file for nginx. rhymix/common/manual/server_config/rhymix-nginx.conf at master · rhymix/rhymix (github.com) I have to apply this rule using caddyfile. I don’t know how to change it in caddyfile format.
There is no any error log
Using apt, ppa
OS: Ubuntu 22.04.3 LTS aarch64
Host: KVM Virtual Machine virt-4.2
Kernel: 5.15.0-1051-realtime
pplus.irodev.xyz {
    root * /var/pplus
    php_fastcgi unix//run/php/php-fpm.sock
RewriteEngine On
# block direct access to templates, XML schema files, config files, dotfiles, environment, etc.
RewriteCond %{REQUEST_URI} !/modules/editor/(skins|styles)/
RewriteRule ^(addons|common/tpl|files/ruleset|(m\.)?layouts|modules|plugins|themes|widgets|widgetstyles)/.+\.(html|xml|blade\.php)$ - [L,F]
RewriteRule ^files/(attach|config|cache)/.+\.(ph(p|t|ar)?[0-9]?|p?html?|cgi|pl|exe|[aj]spx?|inc|bak)$ - [L,F]
RewriteRule ^files/(env|member_extra_info/(new_message_flags|point))/ - [L,F]
RewriteRule ^(\.git|\.ht|\.travis|codeception\.|composer\.|Gruntfile\.js|package\.json|CONTRIBUTING|COPYRIGHT|LICENSE|README) - [L,F]
# static files
RewriteCond %{SCRIPT_FILENAME} !-f
RewriteRule ^(.+)/(addons|files|layouts|m\.layouts|modules|widgets|widgetstyles)/(.*) ./$2/$3 [L]
RewriteRule ^(.+)\.min\.(css|js)$ ./$1.$2 [L]
# all other short URLs
RewriteCond %{SCRIPT_FILENAME} !-d
RewriteRule . index.php [L]
this is .htaccess file that working same with nginx config.
I don’t have time to convert all of those for you, as a volunteer.
You’ll need to use a combination of named request matchers (mostly path_regexp) with directives like error
Are you sure you actually need all those rules though? From their comments it looks like many of them are only needed for “legacy”. If you’re using a new deployment of that CMS, you probably don’t need them.
