Any
Docker or Service
Deb, docker
Paste command here.
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
Traffic between Client and Caddy is beautifully encrypted. But
If there’s a network intrusion (eavesdropping) traffic between Caddy and Http server is not encrypted.
What Is the best practice to avoid that? (or Am I totally missing something)
1- Docker-compose context: I believe that if Caddy and the Targeted server are both configured i nthe same file, Redirection to the ‘‘docker container’’ is made internally (Like the suggested configuration for Vaultwarden). Is this one way to go?
2- Localhost context: If caddy is running on the server itself, doing a: ‘‘localhost’’/127.0.0.1:Port will it keep the packets inside the server without worries?
3- Vlan twist:
-A vlan is configured to allow only Caddy server and target server(s) to be possible. (limited CIDR range)
-Traffic between LAN/other Vlans to this VLAN only allow traffic toward Caddy and 443port
Will this prevent anything? I doubt so.
Sorry for the formatting, since this is not a ‘‘bug’’ but rather looking for best practices.
Thank you
