TLS internal at servers level
Is it possible to use TLS internal module in global options (at servers level) ?
I tried to achieve it, but I get an error log.
I would like to use tls internal for all host using a specific server (:443) instead of use tls internal in each block
logger=admin.api msg=request error error=loading config: loading new config: loading http app module: provision http: it is unnecessary to specify the TLS listener wrapper in the first position because that is the default status_code=400
v2.7.6
Docker
docker compose up -d
    container_name: "caddy"
    image: "<registry>/caddy-with-google-domains-dns:2.7.6"
      metrics:
      proxy:
      vlan:
        ipv4_address: <ip>
      - "<path>/caddy/Caddyfile:/etc/caddy/Caddyfile"
      - "<path>/caddy/config:/config"
      - "<path>/caddy/data:/data"
        admin :2019
        email contact@domain.me
        acme_dns <provider> <token>
        servers :443 {
               listener_wrappers {
                       tls internal
               metrics
        servers {
               metrics
##### EXTERNAL #####
abc.domain.me:12443 {
        reverse_proxy abc:5000
def.domain.me:12443 {
        @public not {
                path /admin
                path /admin/*
        route {
                reverse_proxy @public def:8080
                respond 401
##### INTERNAL #####
ghi.otherdomain.me {
        reverse_proxy ghi:3000
jkl.otherdomain.me {
        reverse_proxy jkl:9090
No. See the docs for what servers accepts: Global options (Caddyfile) — Caddy Documentation
The tls directive is a directive, therefore it must be used inside of a site block. See Caddyfile Concepts — Caddy Documentation
