To summarize: what you submitted is the wrapper for Caddy; it’s a package that makes the libdns package usable by Caddy. That’s great, but that belongs in the caddy-dns org on GitHub. But first the libdns package needs to be brought into the libdns org. So either the author will have to do that, or if it’s unmaintained, you’ll have to fork it and maintain it, and submit a PR (just like you did, but with your fork instead) for me to review it.
Please make requests with curl -v that prove this. You can add response headers in each site block to show which one gets hit as well, like header Test apex and header Test sub for example.
However, I did add the header_up statements b/c I am trying to allow for custom domains to be implemented and according to some docs I needed to do that so that later on in the application I can check the header to know what CNAME was used…if that makes sense
Caddy passes through the original Host upstream by default. You don’t need to do anything to preserve it. That header_up line will replace it with 127.0.0.1 which is not what you want here.
Changing Host only makes sense if you need to do it because the upstream makes some decisions based on hostname and it can’t be the original hostname – in which case you’d typically set X-Forwarded-Host as well so no information is lost.
Also, you don’t need X-Real-IP (and that’s the wrong value to set for it anyways) because X-Forwarded-For is already set with the right value.
The browser wants a certificate that contains the domain name it made the request for. So that means you need a certificate with pm0.11bricks.com in it.
The way CNAMEs work, is it just makes pm0.11bricks.com use custom0.honeystalk.io to resolve an IP address. The browser doesn’t “see” custom0.honeystalk.io at any point, it just sees the same IP address that that domain happens to resolve to (this is all internal to the DNS resolver).
So for this, you will need Caddy’s On-Demand TLS feature. You can’t use wildcard certs to solve this, because you don’t have control of the customer’s DNS such that you can configure Caddy to change a TXT record automatically (at least I hope you don’t, that would be a too high a level of trust that the customer would have granted you, and that’s dangerous).
I am assuming there will be a call to https://honeystalk.io/api/v2/domain-check to see if the custom domain is in the DB. I added a catch-all to see what is passed in to that endpoint but not getting it hit for some reason
Ok, so here is the main part of the Caddyfile. Please not that requests to honeystalk.io ( no subdomain ) should be routed to a different root than the requests to *.honeystalk.io. How would you re-write it with just https:// {...} wrapper?
You don’t need on_demand for domains that are known in your config.
It’s only for domains that are unknown in the config, that Caddy discovers when a client attempts a TLS handshake and provides the domain they want to make a connection for in the SNI field of the handshake.
If you must have a wildcard cert for *.honeystalk.io then that’ll need to be a 4th site block probably just for that, with the appropriate DNS plugin config.
So just to give you some context here, every customer that we have has their own dedicated portal that is essentially a subdomain to honeystalk.io. In that case *.honeystalk.io would work well b/c it would catch all subdomains and serve files from the /account folder.
We also want to offer custom domains to a selected few customers ( that’s is the main reason switching to Caddy…fyi ). So, correct me if i am wrong but I am guessing all four blocks are needed then?
No, you could use On-Demand TLS for your subdomains instead of a wildcard cert (and drop the requirement of building with a DNS plugin altogether), and also handle custom domains the same way with the same site block.
Just make sure the ask endpoint responds with a 200 for valid subdomains as well as custom domains.
When you say drop the requirement of building with a DNS plugin altogether you mean I can achieve having custom domains without the godaddy dns plugin?
If that’s is the case, would you please provide me with the code that would do that
