Stuck on trying to solve challenge (cloudflare)
Unable to solve Cloudflare Challenge.
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.4328673,"logger":"tls.obtain","msg":"lock acquired","identifier":"*.spozorios.com"}
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.4329467,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.spozorios.com"}
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.4331994,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.spozorios.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"zopallen@gmail.com"}
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.4332275,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.spozorios.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"zopallen@gmail.com"}
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.4334633,"logger":"tls.obtain","msg":"lock acquired","identifier":"spozorios.com"}
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.433534,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"spozorios.com"}
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.433734,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["spozorios.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"zopallen@gmail.com"}
Sep 08 12:44:45 caddy-v2 caddy[1356]: {"level":"info","ts":1694169885.4337568,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["spozorios.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"zopallen@gmail.com"}
Sep 08 12:44:46 caddy-v2 caddy[1356]: {"level":"info","ts":1694169886.6099792,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.spozorios.com","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
Sep 08 12:44:46 caddy-v2 caddy[1356]: {"level":"info","ts":1694169886.7144606,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"spozorios.com","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
Debian 12 LXC running on Proxmox 8
  1. Installed go
  2. Installed xcaddy using:
apt install -y debian-keyring debian-archive-keyring apt-transport-https
curl -1sLf 'https://dl.cloudsmith.io/public/caddy/xcaddy/gpg.key' | gpg --dearmor -o /usr/share/keyrings/caddy-xcaddy-archive-keyring.gpg
curl -1sLf 'https://dl.cloudsmith.io/public/caddy/xcaddy/debian.deb.txt' | tee /etc/apt/sources.list.d/caddy-xcaddy.list
apt update
apt install xcaddy
Built Caddy with the CouldFlare Plugin:
xcaddy build --with github.com/caddy-dns/cloudflare
Moved the executable:
mv caddy /usr/bin/
Created a user:
sudo groupadd --system caddy
sudo useradd --system \
    --gid caddy \
    --create-home \
    --home-dir /var/lib/caddy \
    --shell /usr/sbin/nologin \
    --comment "Caddy web server" \
    caddy
Created systemd service:
# caddy.service
# for your installation.
Type=notify
ExecStart=/usr/bin/caddy run --environ --config /var/lib/caddy/Caddyfile
ExecReload=/usr/bin/caddy reload --config/var/lib/caddy/Caddyfile --force
Created Caddyfile in var/lib/caddy/Caddyfile
Proxmox 8 running LXC with Debian 12
service caddy start
	# Optional: set root folder for Caddyfile and Certificates
	storage file_system {
		root /var/lib/caddy
	email redacted@gmail.com
*.spozorios.com, spozorios.com {
		dns cloudflare {redacted}
	# Standard reverse proxy
	@vaultwarden host vaultwarden.spozorios.com
	handle @vaultwarden {
		reverse_proxy 192.168.88.185:8000
Thanks in advance.
There’s no errors in your logs.
