Stripe slash, /about/ to /about
Hi guys, how do stripe slash if my static files are build like this
index.html
- about/index.html
- contact/index.html
- other/index.html
root⋅*⋅/home/team/example.com/public
encode⋅zstd⋅gzip
i want to remove /, for example example.com/about/example.com/about
Ah, you want to strip the slash.
Please check out our docs: Common Caddyfile Patterns — Caddy Documentation
However, note that doing this on index files will break relative links and such.
A better way to go about this is make /about.html in the root of your site instead of /about/index.html. More correct semantically.
Yep; and then do something like:
try_files {path}.html {path}
to hide the file extension.
