Yes sure. Here is the log:
Feb 06 17:24:44 staging-server systemd[1]: Starting Caddy...
Feb 06 17:24:44 staging-server caddy[58600]: caddy.HomeDir=/var/lib/caddy
Feb 06 17:24:44 staging-server caddy[58600]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Feb 06 17:24:44 staging-server caddy[58600]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Feb 06 17:24:44 staging-server caddy[58600]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Feb 06 17:24:44 staging-server caddy[58600]: caddy.Version=v2.6.2 h1:wKoFIxpmOJLGl3QXoo6PNbYvGW4xLEgo32GPBEjWL8o=
Feb 06 17:24:44 staging-server caddy[58600]: runtime.GOOS=linux
Feb 06 17:24:44 staging-server caddy[58600]: runtime.GOARCH=amd64
Feb 06 17:24:44 staging-server caddy[58600]: runtime.Compiler=gc
Feb 06 17:24:44 staging-server caddy[58600]: runtime.NumCPU=2
Feb 06 17:24:44 staging-server caddy[58600]: runtime.GOMAXPROCS=2
Feb 06 17:24:44 staging-server caddy[58600]: runtime.Version=go1.19.2
Feb 06 17:24:44 staging-server caddy[58600]: os.Getwd=/
Feb 06 17:24:44 staging-server caddy[58600]: LANG=en_US.UTF-8
Feb 06 17:24:44 staging-server caddy[58600]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Feb 06 17:24:44 staging-server caddy[58600]: NOTIFY_SOCKET=/run/systemd/notify
Feb 06 17:24:44 staging-server caddy[58600]: HOME=/var/lib/caddy
Feb 06 17:24:44 staging-server caddy[58600]: LOGNAME=caddy
Feb 06 17:24:44 staging-server caddy[58600]: USER=caddy
Feb 06 17:24:44 staging-server caddy[58600]: INVOCATION_ID=9bd8ecb009cd484d9cc6bda5893f20be
Feb 06 17:24:44 staging-server caddy[58600]: JOURNAL_STREAM=8:104766
Feb 06 17:24:44 staging-server caddy[58600]: SYSTEMD_EXEC_PID=58600
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.9126728,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.919793,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"warn","ts":1675704284.9203715,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.9210298,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.921481,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Feb 06 17:24:44 staging-server systemd[1]: Started Caddy.
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.9223676,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003573b0"}
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.92294,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.9234228,"logger":"tls","msg":"finished cleaning storage units"}
Feb 06 17:24:44 staging-server caddy[58600]: {"level":"info","ts":1675704284.927475,"msg":"serving initial configuration"}
Feb 06 17:25:09 staging-server systemd[1]: Reloading Caddy...
Feb 06 17:25:09 staging-server caddy[58731]: {"level":"info","ts":1675704309.8779461,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.8813076,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"39760","headers":{"Accept-Encoding":["gzip"],"Cache-Control":["must-revalidate"],"Content-Length":["184"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.8832307,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"warn","ts":1675704309.8836088,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.8840344,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00037f260"}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.8844795,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.884837,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003573b0"}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.8852694,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.8854008,"logger":"admin.api","msg":"load complete"}
Feb 06 17:25:09 staging-server caddy[58600]: {"level":"info","ts":1675704309.8909974,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Feb 06 17:25:09 staging-server systemd[1]: Reloaded Caddy.
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6878228,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"39330","headers":{"Accept-Encoding":["gzip"],"Content-Length":["1612"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6902158,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"warn","ts":1675706334.6924038,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.692611,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6927636,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6955428,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6960404,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6959133,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0001e1730"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6965697,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6967964,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.696963,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["utm.besnik.net"]}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6976812,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc00037f260"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.698561,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6990087,"logger":"admin.api","msg":"load complete"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.6998444,"logger":"tls.obtain","msg":"acquiring lock","identifier":"utm.besnik.net"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.7019029,"logger":"tls.obtain","msg":"lock acquired","identifier":"utm.besnik.net"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.7023196,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"utm.besnik.net"}
Feb 06 17:58:54 staging-server caddy[58600]: {"level":"info","ts":1675706334.7035363,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Feb 06 17:58:55 staging-server caddy[58600]: {"level":"info","ts":1675706335.7255528,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["utm.besnik.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
Feb 06 17:58:55 staging-server caddy[58600]: {"level":"info","ts":1675706335.725629,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["utm.besnik.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
Feb 06 17:58:56 staging-server caddy[58600]: {"level":"info","ts":1675706336.0897298,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"utm.besnik.net","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
Feb 06 17:58:56 staging-server caddy[58600]: {"level":"info","ts":1675706336.3996553,"logger":"http","msg":"served key authentication","identifier":"utm.besnik.net","challenge":"http-01","remote":"18.118.151.45:27982","distributed":false}
Feb 06 17:58:56 staging-server caddy[58600]: {"level":"info","ts":1675706336.5061448,"logger":"http","msg":"served key authentication","identifier":"utm.besnik.net","challenge":"http-01","remote":"18.236.105.143:61204","distributed":false}
Feb 06 17:58:56 staging-server caddy[58600]: {"level":"info","ts":1675706336.5743754,"logger":"http","msg":"served key authentication","identifier":"utm.besnik.net","challenge":"http-01","remote":"23.178.112.102:29874","distributed":false}
Feb 06 17:58:57 staging-server caddy[58600]: {"level":"info","ts":1675706337.0468037,"logger":"http.acme_client","msg":"authorization finalized","identifier":"utm.besnik.net","authz_status":"valid"}
Feb 06 17:58:57 staging-server caddy[58600]: {"level":"info","ts":1675706337.0468912,"logger":"http.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/952014366/163268940196"}
Feb 06 17:58:57 staging-server caddy[58600]: {"level":"info","ts":1675706337.7899773,"logger":"http.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/03d8a8447abc08156571bbb1adeb13bcf52b"}
Feb 06 17:58:57 staging-server caddy[58600]: {"level":"info","ts":1675706337.7907612,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"utm.besnik.net"}
Feb 06 17:58:57 staging-server caddy[58600]: {"level":"info","ts":1675706337.790849,"logger":"tls.obtain","msg":"releasing lock","identifier":"utm.besnik.net"}
Feb 06 17:59:02 staging-server caddy[58600]: {"level":"info","ts":1675706342.5809731,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/stop","remote_ip":"127.0.0.1","remote_port":"39336","headers":{"Accept-Encoding":["gzip"],"Content-Length":["0"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Feb 06 17:59:02 staging-server caddy[58600]: {"level":"warn","ts":1675706342.5811977,"logger":"admin.api","msg":"exiting; byeee!! 👋"}
Feb 06 17:59:02 staging-server caddy[58600]: {"level":"info","ts":1675706342.5815964,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0001e1730"}
Feb 06 17:59:02 staging-server caddy[58600]: {"level":"info","ts":1675706342.581959,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Feb 06 17:59:02 staging-server caddy[58600]: {"level":"info","ts":1675706342.5819852,"logger":"admin.api","msg":"shutdown complete","exit_code":0}
Feb 06 17:59:02 staging-server systemd[1]: caddy.service: Deactivated successfully.
