Still use Let's Encrypt after set Cloudflare
v1.0.4
Ubuntu 18.04 LTS
caddy -conf ~/.caddy/Caddyfiles/qbit
This is from my ~/.zshrc file
export CLOUDFLARE_EMAIL="XXXX@XXXX"
export CLOUDFLARE_API_KEY="XXXXXXXX"
qbit.ninzero.com {
    gzip
        dns cloudflare
    log /home/ninzero/.caddy/Caddylog/qbit_access.log
    proxy / localhost:8080
I am trying to use Cloudflare for my certificates. But when I run the command, Caddy still ask me to agree Let’s Encrypt’s User Agreement.
Activating privacy features…
Your sites will be served over HTTPS automatically using Let’s Encrypt.
By continuing, you agree to the Let’s Encrypt Subscriber Agreement at:
https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf
Please enter your email address to signify agreement and to be notified
in case of issues. You can leave it blank, but we don’t recommend it.
Email address:
If you run Caddy with the -agree flag in CLI, it should work fine. See https://caddyserver.com/v1/docs/cli
Also, you should be specifying an email address with the -email CLI option, or in the tls directive, like this:
tls your@email.com {
    dns cloudflare
To clarify, when you use the Cloudflare DNS plugin, that doesn’t mean that Cloudflare will provide the certificates. What it does is make it possible to use the ACME DNS challenge and it will use the Cloudflare API to set a TXT record on your domain so that LE can attest that you own the domain. See Challenge Types - Let's Encrypt
Solved. Thank you so much for help.
