I’m testing out my setup and that the whole process works as expected.
- I’m using DNSimple as my DNS provider (
tls { dns dnsimple}
) - I set the environment variables
DNSIMPLE_EMAIL
andDNSIMPLE_API_KEY
(which by the way, should be the DNSimple v1 key and not v2) - I set
-ca https://acme-staging.api.letsencrypt.org/directory
switch when booting up caddy.
I expect the “fake” SSL certificates are written on the disk, but I do not see anything written on $HOME/.caddy
after I visit the page, verifying that an SSL cert is served (but not trusted by my browser).
What else should I try to do? Am I understanding correctly that something should be written into ~/.caddy
