I am setting up a custom domain system for a blogging platform I am making, and it works by having the person setting up the domain CNAME it to my domain (maylog.easrng.us.to), and add a TXT record so I know which blog to serve. My node app does all that, and it works well, but it is HTTP only. I am trying to use Caddy for the on demand TLS so when someone connects to my server from a new CNAME, Caddy will get a Let’s Encrypt cert for the domain and serve HTTPS. When I change the * in my Caddyfile to blog.easrng.us.to (a custom domain set up with my blogging system), it works wonderfully. However, I need to accept any domain, not just that one.
There are no Caddy errors, but Chrome gives me the error ERR_SSL_PROTOCOL_ERROR when connecting, and curl gives curl: (35) error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error
I already tried using :80, :443, but Caddy seems to treat them as hostnames, so I assume that the page I got that information from was for an older version of Caddy.
2020/12/14 20:18:40.543 INFO using adjacent Caddyfile
2020/12/14 20:18:40.547 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["127.0.0.1:2019", "localhost:2019", "[::1]:2019"]}
2020/12/14 20:18:40.547 INFO tls setting internal issuer for automation policy that has only internal subjects but no issuer configured {"subjects": ["*"]}
2020/12/14 20:18:40.554 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000496f50"}
2020/12/14 20:18:40.578 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2020/12/14 20:18:40.578 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2020/12/14 20:18:40.658 INFO pki.ca.local root certificate is already trusted by system {"path": "storage:pki/authorities/local/root.crt"}
2020/12/14 20:18:40.661 DEBUG http starting server loop {"address": "[::]:443", "http3": false, "tls": true}
2020/12/14 20:18:40.664 DEBUG http starting server loop {"address": "[::]:80", "http3": false, "tls": false}
2020/12/14 20:18:40.662 INFO tls cleaned up storage units
2020/12/14 20:18:40.669 INFO autosaved config {"file": "/root/.config/caddy/autosave.json"}
2020/12/14 20:18:40.672 INFO serving initial configuration
2020/12/14 20:18:51.395 DEBUG http.stdlib http: TLS handshake error from xx.xx.xx.xx:52304: no certificate available for 'blog.easrng.us.to'
I am guessing only the last line is relevant. I have on_demand on, so why isn’t it getting certs?
Also, please make sure you use the ask option to validate that the domains are trusted, otherwise someone could run a DDOS against your server by forcing it to issue certs for random domains.
An attacker could just configure a wildcard subdomain like *.badactor.com to point to your server, then make requests like sub-1.badactor.com then sub-2.badactor.com and so on with a bot, forcing your server to issue certs for those. You’ll end up hitting rate limits pretty quickly, and no other domains can be issued. And it’ll fill up your disk space, etc.
So ask is very important to protect against that. Make sure you use it.
