Split Proxy across multiple domains with Cloudflare and security
I currently have Caddy setup with my domains and use Cloudflare DNS proxy (my domains are through Cloudflare so it seemed to make sense at the time). I’ve had issues with things like Autheila for SSO not always working as expected (it seems to lose something in the redirect back and fail then), the Home Assistant webpage not always loading all resources (this seems to get fixed after a few page reloads), immich not always loading right+file upload limits, etc. - it seems like things maybe get filtered out or removed through Cloudflare.
I’d like to still use Cloudflare DNS proxy for “mysite2.com”.
But for most of my selfhosted things that are behind mysite.org, I’d like to move off using the the authenticated origin pull, and Cloudflare DNS proxy, and move to using a LetsEncrypt certificate setup instead.
Is this possible in a single Caddy instance and what is the best way to secure things on the mysite.org side now that it would no longer have some of the “Cloudflare protections” in place? Things like fail2ban or geoblocking (I believe my geoblocking addon is working as expected) would be nice to have.
v2.10.2
FROM caddy:2.10.2-builder AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/cloudflare\
    --with github.com/porech/caddy-maxmind-geolocation\
    --with github.com/RussellLuo/caddy-ext/ratelimit\
    --with github.com/WeidiDeng/caddy-cloudflare-ip\
    --with github.com/fvbommel/caddy-combine-ip-ranges\
    --with github.com/caddyserver/transform-encoder
FROM caddy:2.10.2
Docker Compose Caddy on Linux Mint 22.2
    build: /mnt/dcf652b9-5e69-42fb-924b-37a038d3f30c/Caddy/dockerfile-caddy
    hostname: caddy
      - "443:443/udp"
    env_file: .env
      - /mnt/dcf652b9-5e69-42fb-924b-37a038d3f30c/Caddy/Caddyfile:/etc/caddy/Caddyfile
      - /mnt/dcf652b9-5e69-42fb-924b-37a038d3f30c/Caddy/caddyconfig:/config
      - /mnt/dcf652b9-5e69-42fb-924b-37a038d3f30c/Caddy/caddydata:/data
      - /mnt/dcf652b9-5e69-42fb-924b-37a038d3f30c/Caddy/origin-pull-ca.pem:/etc/ssl/certs/origin-pull-ca.pem:ro
      - /mnt/dcf652b9-5e69-42fb-924b-37a038d3f30c/Caddy/GeoLite2-Country.mmdb:/usr/share/GeoIP/GeoLite2-Country.mmdb:ro
      - /mnt/dcf652b9-5e69-42fb-924b-37a038d3f30c/Caddy/AccessLogs:/var/log/mydomain.org
  default:
    external: true
	acme_dns cloudflare xxxxxxxx
	servers {
		trusted_proxies cloudflare {
			interval 12h
			timeout 20s
(headers) {
	header Content-Security-Policy "upgrade-insecure-requests"
	header Referrer-Policy "same-origin"
	header Strict-Transport-Security "max-age=31536000; includeSubDomains"
	header X-XSS-Protection "1; mode=block"
	header X-Content-Type-Options "nosniff"
	header X-Robots-Tag "noindex, nofollow, nosnippet, noarchive"
*.mysite.org {
		format transform "{common_log}"
		output file /var/log/mysite.org/access.log
		client_auth {
			mode require_and_verify
			trust_pool file {
				pem_file /etc/ssl/certs/origin-pull-ca.pem
	@mygeofilter {
		maxmind_geolocation {
			db_path "/usr/share/GeoIP/GeoLite2-Country.mmdb"
			allow_countries US
	@immich host immich.mysite.org
	handle @immich {
		import headers
		reverse_proxy @mygeofilter immich-server:2283
	@homeassistant host homeassistant.mysite.org
	handle @homeassistant {
		import headers5
		reverse_proxy @mygeofilter 192.168.50.164:8123
	@Joplin host joplin.mysite.org
	handle @Joplin {
		import headers
		reverse_proxy @mygeofilter joplin-app:22300
	@Auth host auth.mysite.org
	handle @Auth {
		import headers
		reverse_proxy @mygeofilter authelia-app:9091 {
			header_down -Access-Control-Allow-Origin
	@hoader host hoard.mysite.org
	handle @hoader {
		import headers
		reverse_proxy @mygeofilter hoarder-app:3000
	@ghost1 host ghost.mysite.org
	handle @ghost1 {
		import headers
		reverse_proxy @mygeofilter site1ghost-app:2368
		abort
*.mysite2.com {
		output file /var/log/mysite2.com/access.log
		client_auth {
			trust_pool file {
	@mygeofilter {
			allow_countries US
	@ghost2 host mysite2.com
	handle @ghost2 {
		import headers
		reverse_proxy @mygeofilter site2ghost-app:2368
