I have a static website with try_files and that works as expected. Now, I am trying to add a special handler for a specific route /ip
. Though it just keeps loading the index.html
N/A
caddy version
Running using Docker, within a docker-compose.
Docker
N/A
N/A
servers :80,:443 {
protocols h1 h2c h2 h3
(security_headers) {
header * {
# enable HSTS
# https://cheatsheetseries.owasp.org/cheatsheets/HTTP_Headers_Cheat_Sheet.html#strict-transport-security-hsts
# NOTE: Read carefully how this header works before using it.
# If the HSTS header is misconfigured or if there is a problem with
# the SSL/TLS certificate being used, legitimate users might be unable
# to access the website. For example, if the HSTS header is set to a
# very long duration and the SSL/TLS certificate expires or is revoked,
# legitimate users might be unable to access the website until
# the HSTS header duration has expired.
# The recommended value for the max-age is 2 year (63072000 seconds).
# But we are using 1 hour (3600 seconds) for testing purposes
# and ensure that the website is working properly before setting
# to two years.
Strict-Transport-Security "max-age=3600; includeSubDomains; preload"
# https://cheatsheetseries.owasp.org/cheatsheets/HTTP_Headers_Cheat_Sheet.html#x-content-type-options
# clickjacking protection
# https://cheatsheetseries.owasp.org/cheatsheets/HTTP_Headers_Cheat_Sheet.html#x-frame-options
X-Frame-Options "SAMEORIGIN"
# xss protection
# https://cheatsheetseries.owasp.org/cheatsheets/HTTP_Headers_Cheat_Sheet.html#x-xss-protection
# Remove -Server header, which is an information leak
# Remove Caddy from Headers
-Server
# https://cheatsheetseries.owasp.org/cheatsheets/HTTP_Headers_Cheat_Sheet.html#referrer-policy
Referrer-Policy strict-origin-when-cross-origin
kamaleshwar.com:80, kamaleshwar.com:443 {
# serve from static directory with default as index.html
root * /usr/share/caddy/kamaleshwar
file_server {
index index.html
route /ip {
respond "{remote_host}"
try_files {path} /index.html
import security_headers
