Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I’d like to limit my public instance of caddy only to clients that have a specific certificate (added manually to android clients and to browsers) like I do with ssh.
How can I do that ?
I managed to have caddy working with any client. I’d like to limit access to specific clients.
Thanks.
So this will prevent any client thag does not have the certificate installed to go further the authentication and connection will be refused.
This should dramatically improve security yes ?
I can no longer use a vpn to secure the access to my local resources so I have installed caddy and will implement this certificate restriction in the hope of having a security as good as the one I had with vpn.
If you have hother suggestions, I interested.
Thanks
That’s very useful. Thanks !
I guess fail2ban would be useful too.
But caddy will be behind a nat (with port fw) that I don’t manage.
So I dont see how I can block based on the ip
Oh ! I think I understand.
Does caddy look for originating IP in the HTTP headers ?
If yes that can solve my NAT problem.
But at the same time it means it can be faked by the client, right ?
The remote_ip matcher looks at the IP on the TCP packets it received. If there’s no proxy between the client and Caddy (like a CDN like CloudFlare or something, or Docker’s userland proxy) then that IP address should be correct.
The matcher may optionally look at the X-Forwarded-For header if you tell it to, but yes, that can be tampered with.
I mean, check the IP address in Caddy’s logs. If they look like WAN IPs and not private IPs (the IP of your router), then it’s probably fine. I think in that case it would be doing DNAT (for port forwarding) so it only changes the destination address but not the source address.
