Basically, you can fill in the version in the text box next to each plugin in the table on the download page. It adds @v1.1.2 to the end of the plugin reference.
But I think @greenpau may need to tell the Caddy site to use the latest tag of his plugins… or there might be a bug that @matt needs to look into.
Thanks, didn’t realize that it is an input field and not just a label, that works as a workaround.
I bet I know what is happening. The build server keeps a cache of each build to reduce load and wait times for common builds.
However I was not able to figure out how to make it version-aware (unless the user specifies a version). It’s basically a glorified wrapper over go build, which just uses the the latest version of each module. But I don’t know a good way to know yet whether any of the direct dependencies have any updates from the prior build that was cached.
