Because I am using a letsencrypt wildcard cert generated by certbot according to docs caddy won’t do automatic http rewrite. Fine but when I do it I get a directive error for r.
Error during parsing: Unknown directive 'r'
FYI, without rewrite section I get no errors and caddy starts.
Getting closer but the http to https rewrite is not working (although no directive error).
The log to stdout logs nothing about the rewrite so I have no idea if it’s ignored or flawed or what.
the commented lines are my various attempts.
Any help here? Wondering if I should be using a redir instead
It’s not the biggest community, and sometimes the volunteers don’t manage to get around to helping out every request inside of 24hrs (the developer offers 1-2day turnaround basic email support for their commercial licenses, same-day response for extended support).
That solution is a good one. Here’s an alternate approach with a single site definition:
http://example.com, https://example.com {
import wildcard_cert
root /mnt/data/webs/main
redir {
if {scheme} is HTTP
/ https://{host}{uri}
This is 100% dependent on whether Caddy is at the edge or not. {scheme} will pick up whatever the client connecting to Caddy used, and it’ll always be available; if it’s being directly connected to by your users, it’s the only one that matters.
On the other hand, there’s no guarantee that {>X-Forwarded-Proto} will be there - it’s only used as a common standard for transparent proxies. But if you know it’ll be there - maybe because Caddy is behind another proxy you’ve configured to send that header - and you want to dictate how the actual user connects, use that instead.
