I’ve been running this config for a couple years now and for some reason certificates are not renewing. I’ve rolled the dns key to make sure that wasn’t the issue. Not sure what is going on. Any advice on what to check next?
caddy[3806126]: {"level":"error","ts":1680888660.7025175,"logger":"http.handlers.reverse_proxy","msg":"aborting wit
v2.6.4
xcaddy custom build
Ubuntu
Description=Caddy Reverse Proxy
ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile --log /etc/caddy/caddy.log
(snip) {
# Enable HSTS
# Referrer Policy retains much of the referrers usefulness while mitigating the risk of leaking data
# Disable FLoC tracking
Permissions-Policy interest-cohort=()
# Gets the clients IP address
X-Real-IP {http.request.remote}
# Forwards clients IP
X-Forwarded-For {remote_host}
# Stops pages from loading when they detect reflected cross-site scripting attacks
# Disable clients from sniffing the media type
# Clickjacking protection
X-Frame-Options "DENY"
issuer acme {
email "My Email Address"
dns cloudflare "My Cloudflare key"
resolvers 1.1.1.1 1.0.0.1
encode zstd gzip
test.xtraxtra.com {
reverse_proxy http://192.168.1.54:9000
import snip
