Simple path matching
I’m trying to match URLs containing “profile” with a specific pattern:
/some-id/profile/some-other-url-part/and-another
This is a simple Caddyfile I am using:
:2015
@profile {
    path */profile/*
handle @profile {
  respond "Hello, profile!"
respond "Hello, world!"
Expected behavior: Match paths with exactly one segment before “profile” and any number after.
Current behavior:
  • localhost:2015/a/profile/s returns “Hello, profile!” (correct)
  • localhost:2015/a/profile/s/d returns “Hello, world!” (incorrect)
  • Previous matcher */profile/* was too permissive, matching multiple segments before “profile”
N/A
2.8.4 on alpine
Installed locally via homebrew and also tested in Docker
macOS 15.1.1
caddy run --config Caddyfile
N/A
@profile {
    path /*/profile/*
handle @profile {
You should use path_regexp for this case. The path matcher does fast prefix and fast suffix matching, it doesn’t stop at path segments.
Might a {path.*} placeholder be useful here for precision and speed?
There’s no base matcher for it, so you’d need to test it with CEL. It would look like:
@profile `{path.1} == "profile"`
respond @profile "Hello, profile!"
Not quite the same logically as /*/profile/* though; it matches on /foo/profile as well as /foo/profile/bar.
But it does match exactly your specified example behaviour; exactly one segment, then another segment “profile”, then any number of segments (including zero) afterwards.
