Version 2.2.1
Ubuntu 20.04 in Docker using custom image to include duckdns DNS challenge
Dockerfile:
FROM caddy:2.2.1-builder-alpine AS builder
RUN xcaddy build \
--with github.com/caddy-dns/duckdns
FROM caddy:2.2.1-alpine
version: "3"
image: custom/caddy2:2.2.1
- TZ=America/Chicago
- ACME_AGREE=true
- $PWD/caddyfile:/etc/caddy/Caddyfile
- $PWD/caddy_data:/data
- $PWD/caddy_config:/config
router.example.duckdns.org {
reverse_proxy 10.0.10.250.:5800
dns duckdns {env.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx}
output file $PWD/caddy.log
I am unable to reach the host. I am trying to use Caddy to access 2 different types of services.
- Webpages running in docker on the server. This server is the same place where Caddy is running
- Webpages running outside of the server e.g. router
{"level":"info","ts":1613184206.7064419,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1613184206.709996,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1613184206.711087,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000398e70"}
{"level":"info","ts":1613184206.7111785,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1613184206.711202,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1613184206.7117474,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["router.example.duckdns.org"]}
{"level":"info","ts":1613184206.7127964,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1613184206.7128134,"msg":"serving initial configuration"}
{"level":"info","ts":1613184206.714057,"logger":"tls.obtain","msg":"acquiring lock","identifier":"router.example.duckdns.org"}
{"level":"info","ts":1613184206.71545,"logger":"tls.obtain","msg":"lock acquired","identifier":"router.example.duckdns.org"}
{"level":"info","ts":1613184206.7198553,"logger":"tls","msg":"cleaned up storage units"}
{"level":"info","ts":1613184206.7255352,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["router.example.duckdns.org"]}
{"level":"info","ts":1613184206.725569,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["router.example.duckdns.org"]}
{"level":"info","ts":1613184207.7788768,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"router.example.duckdns.org","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613184208.8024192,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"router.example.duckdns.org","challenge_type":"dns-01","error":"no memory of presenting a DNS record for router.example.duckdns.org (probably OK if presenting failed)"}
{"level":"error","ts":1613184208.9209912,"logger":"tls.obtain","msg":"will retry","error":"[router.example.duckdns.org] Obtain: [router.example.duckdns.org] solving challenges: presenting for challenge: adding temporary record for zone duckdns.org.: DuckDNS request failed, expected (OK) but got (KO), url: [https://www.duckdns.org/update?domains=puldal.duckdns.org&token=&txt=7QCQ1ZKq8K5FflkfeaikEbfWGK-WkdCegM-dFjcUPN4&verbose=true], body: KO (order=https://acme-v02.api.letsencrypt.org/acme/order/112606271/7875550488) (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":2.205521407,"max_duration":2592000}
I have tried to search for sample configuration.
