caddy version
v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
My issue can be reproduced by simply running caddy run
and POSTing a config to it.
Linux Mint, manual invocation of Caddy (doesn’t really matter in this case)
`caddy run`
N/A
"admin": {
"config": {
"persist": false
"storage": {
"module": "file_system",
"root": "/tmp/tmp.lkyhcls60L/storage/"
"apps": {
"pki": {
"certificate_authorities": {
"customca": {
"name": "my custom CA name",
"root_common_name": "custom CA - root",
"intermediate_common_name": "custom CA - intermediate",
"install_trust": false
"tls": {
"certificates": {
"automate": [
"example.com",
"example.home.arpa"
"automation": {
"policies": [
"subjects": [
"example.com",
"example.home.arpa"
"issuers": [{
"module": "internal",
"ca": "customca",
"lifetime": 300000000000
"disable_ocsp_stapling": true
"logging": {
"logs": {
"default": {
"level": "DEBUG"
When playing with the PKI and reproducing something in my lab, I noticed caddy doing something I was not expecting it to do.
The UTC time is not only used for Caddys log but also for the internal PKI when creating local certs.
I had a hunch that this is the case after reading this thread: How to set log time to +0800 + another one I can’t find anymore where Matt was mentioning that he is on a mission to decrease the size of the Caddy binary and including the Golang timezone db etc would blow it up?!
This could cause issues for very short lived local testing certs - 5 minutes for example.
The default value for the lifetime is 24h, but this can be altered using the lifetime attribute.
https://caddyserver.com/docs/json/apps/tls/automation/policies/issuers/internal/
lifetime
The validity period of certificates.
Duration can be an integer or a string. An integer is interpreted as nanoseconds. If a string, it is a Go time.Duration value such as
300ms
,1.5h
, or2h45m
; valid units arens
,us
/µs
,ms
,s
,m
,h
, andd
So the config section of interest is this one:
"issuers": [{
"ca": "customca",
I noticed that you can’t have the lifetime be smaller than 300000000000 nanoseconds (5min).
The docs veeery kind of give you the idea you could have the lifetime be any valid value (though not longer than the root CA probably). This seems to be hard coded here: caddy/modules/caddypki/acmeserver/acmeserver.go at a1c41210d34c629c3b5cdbdca74c540fde752aad · caddyserver/caddy · GitHub
Although this is related to my original problem (I tried 1min as I needed it to be really short), the main problem is the usage of UTC globally throughout Caddy.
Here is the invocation of Caddy where I demonstrate the issue:
❯ timedatectl
Local time: Sun 2022-05-22 20:47:06 CEST
Universal time: Sun 2022-05-22 18:47:06 UTC
RTC time: Sun 2022-05-22 18:47:06
Time zone: Europe/Berlin (CEST, +0200)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
❯ caddy run
2022/05/22 18:47:13.147 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/05/22 18:47:13.147 INFO serving initial configuration
2022/05/22 18:48:06.764 INFO admin.api received request {"method": "POST", "host": "localhost:2019", "uri": "/load", "remote_ip": "127.0.0.1", "remote_port": "44872", "headers": {"Accept":["*/*"],"Content-Length":["828"],"Content-Type":["application/json"],"User-Agent":["curl/7.68.0"]}}
2022/05/22 18:48:06.764 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/05/22 18:48:06.765 INFO pki.ca.customca root certificate trust store installation disabled; unconfigured clients may show warnings {"path": "storage:pki/authorities/customca/root.crt"}
2022/05/22 18:48:06.765 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0003cca10"}
2022/05/22 18:48:06.765 INFO admin.api load complete
2022/05/22 18:48:06.766 INFO tls cleaning storage unit {"description": "FileStorage:/tmp/tmp.lkyhcls60L/storage/"}
2022/05/22 18:48:06.766 INFO tls finished cleaning storage units
2022/05/22 18:48:06.766 INFO tls.obtain acquiring lock {"identifier": "example.com"}
2022/05/22 18:48:06.766 INFO tls.obtain acquiring lock {"identifier": "example.home.arpa"}
2022/05/22 18:48:06.768 INFO admin stopped previous server {"address": "tcp/localhost:2019"}
2022/05/22 18:48:06.769 INFO tls.obtain lock acquired {"identifier": "example.com"}
2022/05/22 18:48:06.769 INFO tls.obtain lock acquired {"identifier": "example.home.arpa"}
2022/05/22 18:48:06.769 DEBUG tls.obtain trying issuer 1/1 {"issuer": "customca"}
2022/05/22 18:48:06.770 DEBUG pki.ca.customca using intermediate signer {"serial": "102486882956661856687520432921376090461", "not_before": "2022-05-22 18:48:06 +0000 UTC", "not_after": "2022-05-29 18:48:06 +0000 UTC"}
2022/05/22 18:48:06.770 INFO tls.obtain certificate obtained successfully {"identifier": "example.com"}
2022/05/22 18:48:06.770 INFO tls.obtain releasing lock {"identifier": "example.com"}
2022/05/22 18:48:06.770 INFO tls.obtain certificate obtained successfully {"identifier": "example.home.arpa"}
2022/05/22 18:48:06.770 INFO tls.obtain releasing lock {"identifier": "example.home.arpa"}
2022/05/22 18:48:06.771 DEBUG tls.cache added certificate to cache {"subjects": ["example.home.arpa"], "expiration": "2022/05/22 18:53:06.000", "managed": true, "issuer_key": "customca", "hash": "e1758808081cdd91ea2e947b934c5b8d5e48e4a7369da7028f109a9e275eb3a3", "cache_size": 1, "cache_capacity": 10000}
2022/05/22 18:48:06.771 DEBUG tls.cache added certificate to cache {"subjects": ["example.com"], "expiration": "2022/05/22 18:53:06.000", "managed": true, "issuer_key": "customca", "hash": "e27ac2ff83476e1dbe5975d3b658cda7d0afec6fd8988e8a0226188fb9115b06", "cache_size": 2, "cache_capacity": 10000}
^C2022/05/22 18:48:10.906 INFO shutting down {"signal": "SIGINT"}
2022/05/22 18:48:10.906 WARN exiting; byeee!! 👋 {"signal": "SIGINT"}
2022/05/22 18:48:10.906 INFO tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc0003cca10"}
2022/05/22 18:48:10.907 INFO admin stopped previous server {"address": "tcp/localhost:2019"}
2022/05/22 18:48:10.907 INFO shutdown complete {"signal": "SIGINT", "exit_code": 0}
❯ openssl x509 --enddate --startdate -in storage/certificates/customca/example.com/example.com.crt -noout
notAfter=May 22 18:53:06 2022 GMT
notBefore=May 22 18:48:06 2022 GMT
So you can see the certs have a timestamp which is in the past. This might not be an issue for certs with a default value of 24h but for shorter ones it could very well be.
So my question is: Is it intended behavior for the internal PKI to create its CA and its certs based on the UTC time even though the process could know the real timezone the server is running on?
For logs I get it, but for certs I really don’t. Maybe I just need some more words on why this is and why I can’t have there short lived certs on a Caddy instance which is not UTC.
See above
Linked within the text
