Hi,
I want to use Caddy in front of my apps including Elasticsearch 6.3 , Kibana 6.3 and so on but no luck with a proper setup. My Caddy version: 0.10.10
and for test purposes, I run Caddy’s executable by providing a config file containing below configuration.
*:80 {
tls off
proxy /kibana localhost:5601 {
without /kibana
proxy /app/kibana localhost:5601
I have a vagrant machine with ip address 192.168.50.50
I can reach Kibana properly through its port, 192.168.50.50:5601
, but for sure I want to use Caddy not to use ports and enable an endpoint for that, /kibana
An additional information; 192.168.50.50:5601
redirects to 192.168.50.50:5601/app/kibana
, hence the 2nd proxy configuration above.
I looked at documentation and tried few different things but no luck. It is clear I miss something but couldn’t find the way out of it.
Appreciate any help.
