Setting Up Logging - error received
I would like to enable logging so that I can see traffic to my sites. I attempted to read the documentation but I may not be reading it correctly. I added the log block below to my config, restarted the service and it fails restart stating that it couldn’t recognize the directive: output.
Please keep in mind that I am not a developer and do not understand json. I simply attempted to read the cryptic Caddy documentation and try to configure Caddy. I am attempting to self-host at home both my reverse proxy server and web server. Caddy is installed on one Red Hat server and my web server is on a separate server.
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:104: unrecognized directive: output
dnf install ‘dnf-command(copr)’
dnf copr enable @caddy/caddy
dnf install caddy
Red Hat Enterprise Linux release 8.9 (Ootpa)
systemctl enable --now caddy
# caddy.service
# for your installation.
Type=notify
# domain name.
www.edscloud.org {
        root * /usr/share/caddy
        # Reverse to vm server teststuff
        reverse_proxy "webserverip":8080
        # php_fastcgi localhost:9000
edscloud.org {
        redir https://www.{host}{uri}
rss.edscloud.org {
        reverse_proxy "webserverip":81
www.androidsdream.net {
        #        file_server
androidsdream.net {
        redir https://www.androidsdream.net{uri}
                roll_size 1gb
                roll_keep 5
                roll_keep_for 720h
Directives go inside site blocks.
Basically the Caddyfile parser is seeing log as a domain name, and then output as a directive, which is wrong. You have to move log into your sites.
