carlosvillu
(Carlos Villuendas Zambrana)
October 17, 2016, 12:46pm
#1
Hi guys,
I would like use Caddy in my new project. Which is a SPA built with ReactJS. I am using React-Router and all URLs must go to index.html. For example:
https://myproject.com/ → index.html
https://myproject.com/user/edit → index.html
But what happing is that when I try it I get a 404. Because of course there isnt a user/edit/index.html folder structure in my public folder.
Any one of you can help me ?!
Thx!
Carlos.
matt
(Matt Holt)
October 17, 2016, 2:27pm
#2
Take a look at the rewrite
middleware - it should make it pretty easy to turn everything into index.html.
carlosvillu
October 17, 2016, 2:46pm
#3
i supposed to be using that middleware. And my Caddy File look like:
rewrite { regexp (.*) to / }
But I get this error:
(master) λ caddy 2016/10/17 16:44:34 Caddyfile:2 - Parse error: Unknown directive 'regexp'
matt
(Matt Holt)
October 17, 2016, 10:15pm
#4
The first line of your Caddyfile must always contain the address of the site you want to serve.
The Caddyfile always starts with the address of the site to serve
carlosvillu
October 17, 2016, 10:51pm
#5
Do you mean something like “localhost:3000”?!
I put it but is the same 404
Really I am the first who want to use Caddy for a SPA ?!
slightfoot
(Simon Lightfoot)
October 22, 2016, 4:24pm
#6
Your rewrite is wrong it should be something like this:
rewrite { to {path} {path}/ /index.html }
Make sure you read the docs
zwack
(Sebastian Zwack)
November 21, 2016, 12:22pm
#8
I used this rewrite for my SPA too. However I also want to preserve the original path.
For that I tried this:
to {path} {path} /index.html{uri}
which gives me a 503 error. redir
does the same. Is there a way to redirect to index.html but then allow the browser to route the remainding path (html5 style)?
slightfoot
(Simon Lightfoot)
November 21, 2016, 1:06pm
#9
Sounds perfectly correct to me. The file /index.html/user/edit
doesn’t exist as a file so is not going to be rewritten.
Perhaps you want to rewrite to a query string?
rewrite {
to {path} {path}/ /index.html?{uri}
Or, a fragment?
rewrite {
to {path} {path}/ /index.html#{uri}
zwack
(Sebastian Zwack)
November 21, 2016, 2:18pm
#10
Thanks, but no, I really mean that Caddy should always return index.html’s content regardless of the url. The browser will then do frontend routing.
In Apache this is working for me using the RewriteEngine. Here are the docs for this setup for different servers:
slightfoot
(Simon Lightfoot)
November 21, 2016, 2:38pm
#11
And that’s exactly what I told you how to do previously. It matches the angular docs right there. If its not a file or directory then redirect the user to index.html
rewrite {
zwack
(Sebastian Zwack)
November 21, 2016, 2:59pm
#13
Nevermind, had the wrong config active.
sfabriece
(Fabriece Sumuni)
December 6, 2016, 12:03am
#14
@zwack what did you end up with?
zwack
(Sebastian Zwack)
December 6, 2016, 8:58am
#15
It works like suggested. I now use this config:
rewrite {
if {path} not_match ^/api
system
(system)
closed
March 6, 2017, 8:58am
#16
