v2.3.0
As per caddy instructions.
Ubuntu 20.04LTS on rPi 4
sudo systemctl start caddy.service
n/a
my-domain.com {
level INFO
output file /home/ubuntu/caddy.log {
roll_size 10MB
roll_keep 10
tls user@my-domain.com
reverse_proxy localhost:8080
basicauth * {
userName xQDBBfDxxxdxxxxxxxtswfhsfdhdfxxxxxxxxxxYYASDxxxxxxxdgfhjdfghsf
I’ve got my bitwardenrs instance running and thought it’d be good to provide some layers of protection. Especially after seeing this.
I tried setting basicauth in caddy, which is fine for my initial url, but as soon as I try to login (e.g. https://my-domain.com/vault/), it immediately logs me out. Actually, it very briefly (milliseconds) flashes the /vault/ but then logs out and errors.
I’ve used the * wildcard in the caddy basicauth directive, which I would’ve thought that would allow full access everywhere, but I guess that’s not quite right.
Any ideas?
Thanks
Logged out
Your login session has expired
Duplicated the basicauth directive for the relevant areas within bitwarden e.g. /vault/ etc. but the ‘session expired’ problem persists.
