v2.5.0
systemctl start caddy
Linux
Docker-compose.yml
db:
image: postgres
- ./data/db:/var/lib/postgresql/data
- POSTGRES_DB=postgres
- POSTGRES_USER=postgres
- POSTGRES_PASSWORD=postgres
backend:
image: arquimedia-backend
- ./data/backend:/code/static/images
depends_on:
- db
command: gunicorn Arquimedia.wsgi:application --bind 0.0.0.0:8000
- 127.0.0.1:8001:8000
frontend:
image: arquimedia-frontend
restart: always
depends_on:
- backend
command: "nginx -g 'daemon off;'"
- 127.0.0.1:8002:3000
arquimedia.pt, www.arquimedia.pt {
encode gzip zstd
handle /api/* {
uri strip_prefix /api
file_server <project-path>/data/backend/*
@notStatic {
not path /images/*
reverse_proxy @notStatic localhost:8001
reverse_proxy localhost:8002
I’m trying to get static files on <project-path>/data/backend
but the response come as a blank page, either for existing files or non existing.
