Hello again. So now, first time since I posted this thread, my website is down and unreachable. I will now keep it down to be able to debug. Usually I can do a docker stop caddy followed by a docker start caddy to get the site up again.
I’m able to log into my server through SSH and here I’ve tried a curl -v.
curl -v https://bonsy.se
* Trying 64.225.66.142:443...
* TCP_NODELAY set
* Connected to bonsy.se (64.225.66.142) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* subject: CN=bonsy.se
* start date: Feb 4 10:55:59 2022 GMT
* expire date: May 5 10:55:58 2022 GMT
* subjectAltName: host "bonsy.se" matched cert's "bonsy.se"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x558a6690a880)
> GET / HTTP/2
> Host: bonsy.se
> user-agent: curl/7.68.0
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Tue, 08 Feb 2022 10:10:57 GMT
* Connection #0 to host bonsy.se left intact
Some debug logs from same time in Docker
"level":"debug",
"ts":1644314928.1362245,
"logger":"tls.handshake",
"msg":"choosing certificate",
"identifier":"bonsy.se",
"num_choices":1
"level":"debug",
"ts":1644314928.136262,
"msg":"default certificate selection results",
"subjects":[
"bonsy.se"
"managed":true,
"issuer_key":"acme-v02.api.letsencrypt.org-directory",
"hash":"bee36bfe4698584977f2c81c8c4b4212a0a2a9ad767fdac937c044a0eae82928"
"level":"debug",
"ts":1644314928.1362693,
"msg":"matched certificate in cache",
"subjects":[
"bonsy.se"
"managed":true,
"expiration":1651748158,
"level":"debug",
"ts":1644314928.1393726,
"logger":"http.handlers.rewrite",
"msg":"rewrote request",
"request":{
"remote_addr":"64.225.66.142:50098",
"proto":"HTTP/2.0",
"method":"GET",
"host":"bonsy.se",
"uri":"/",
"headers":{
"User-Agent":[
"curl/7.68.0"
"Accept":[
"tls":{
"resumed":false,
"version":772,
"cipher_suite":4865,
"proto":"h2",
"proto_mutual":true,
"server_name":"bonsy.se"
"method":"GET",
"uri":"/index.php"
"level":"debug",
"ts":1644314928.1394913,
"logger":"http.reverse_proxy.transport.fastcgi",
"msg":"roundtrip",
"request":{
"proto":"HTTP/2.0",
"method":"GET",
"host":"bonsy.se",
"uri":"/index.php",
"headers":{
"X-Forwarded-For":[
"64.225.66.142"
"X-Forwarded-Proto":[
"https"
"User-Agent":[
"curl/7.68.0"
"Accept":[
"tls":{
"resumed":false,
"version":772,
"proto":"h2",
"dial":"php:9000",
"env":{
"AUTH_TYPE":"",
"CONTENT_LENGTH":"",
"CONTENT_TYPE":"",
"DOCUMENT_ROOT":"/var/www/public",
"DOCUMENT_URI":"/index.php",
"GATEWAY_INTERFACE":"CGI/1.1",
"HTTPS":"on",
"HTTP_ACCEPT":"*/*",
"HTTP_HOST":"bonsy.se",
"HTTP_USER_AGENT":"curl/7.68.0",
"HTTP_X_FORWARDED_FOR":"64.225.66.142",
"HTTP_X_FORWARDED_PROTO":"https",
"PATH_INFO":"",
"QUERY_STRING":"",
"REMOTE_ADDR":"64.225.66.142",
"REMOTE_HOST":"64.225.66.142",
"REMOTE_IDENT":"",
"REMOTE_PORT":"50098",
"REMOTE_USER":"",
"REQUEST_METHOD":"GET",
"REQUEST_SCHEME":"https",
"REQUEST_URI":"/",
"SCRIPT_FILENAME":"/var/www/public/index.php",
"SCRIPT_NAME":"/index.php",
"SERVER_NAME":"bonsy.se",
"SERVER_PROTOCOL":"HTTP/2.0",
"SERVER_SOFTWARE":"Caddy/v2.4.6",
"SSL_CIPHER":"TLS_AES_128_GCM_SHA256",
"SSL_PROTOCOL":"TLSv1.3"
"level":"debug",
"ts":1644315057.5020938,
"logger":"http.handlers.reverse_proxy",
"msg":"upstream roundtrip",
"upstream":"php:9000",
"duration":129.362634004,
"request":{
"proto":"HTTP/2.0",
"method":"GET",
"host":"bonsy.se",
"uri":"/index.php",
"headers":{
"User-Agent":[
"curl/7.68.0"
"Accept":[
"X-Forwarded-For":[
"64.225.66.142"
"https"
"tls":{
"resumed":false,
"version":772,
"proto":"h2",
"error":"dialing backend: dial tcp 172.19.0.3:9000: connect: connection timed out"
"level":"error",
"ts":1644315057.5021753,
"logger":"http.log.error",
"msg":"dialing backend: dial tcp 172.19.0.3:9000: connect: connection timed out",
"request":{
"proto":"HTTP/2.0",
"method":"GET",
"host":"bonsy.se",
"uri":"/",
"headers":{
"User-Agent":[
"curl/7.68.0"
"Accept":[
"tls":{
"resumed":false,
"version":772,
"proto":"h2",
"duration":129.362957129,
"status":502,
"err_id":"yxibd6cuj",
"err_trace":"reverseproxy.statusError (reverseproxy.go:886)"
I would really appreciate any guidens/help to continue debugging so I’m able to fix this issue.
I do seem to get the same result if I curl -v the IP-address as well.
PHP logs only show this: (which was yesterday when things stopped working):
php_1 | 172.19.0.4 - 07/Feb/2022:06:50:08 +0000 "POST /index.php" 200
I can verify that my PHP server is running
.....$ docker-compose exec php php -v
PHP 8.1.0 (cli) (built: Nov 30 2021 06:20:01) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.0, Copyright (c) Zend Technologies
IP-address inspection
# docker inspect -f '{{range.NetworkSettings.Networks}}{{.IPAddress}}{{end}}' bonsy_php
172.19.0.3
# docker inspect -f '{{range.NetworkSettings.Networks}}{{.IPAddress}}{{end}}' bonsy_caddy
172.19.0.4
