Serve reverse proxied subdomain as root
The page isn’t redirecting properly when I want to set my wp.dieschoenewolke.com as dieschoenewolke.com.
*   Trying 123.456.789.0:80...
* Connected to dieschoenewolke.com (123.456.789.0) port 80 (#0)
> GET / HTTP/1.1
> Host: dieschoenewolke.com
> User-Agent: curl/7.88.1
< Connection: close
< Location: https://dieschoenewolke.com/
< Server: Caddy
< Date: Fri, 02 Feb 2024 06:50:38 GMT
< Content-Length: 0
* Closing connection 0
* Issue another request to this URL: 'https://dieschoenewolke.com/'
*   Trying 123.456.789.0:443...
* Connected to dieschoenewolke.com (123.456.789.0) port 443 (#1)
* ALPN: offers h2,http/1.1
*  CApath: /etc/ssl/certs
* ALPN: server accepted h2
*  subject: CN=dieschoenewolke.com
*  start date: Jan 29 11:39:10 2024 GMT
*  expire date: Apr 28 11:39:09 2024 GMT
*  subjectAltName: host "dieschoenewolke.com" matched cert's "dieschoenewolke.com"
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: dieschoenewolke.com]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x555d1846bc80)
> GET / HTTP/2
> accept: */*
< HTTP/2 302
< location: https://wp.dieschoenewolke.com
< server: Caddy
< content-length: 0
< date: Fri, 02 Feb 2024 06:50:38 GMT
* Connection #1 to host dieschoenewolke.com left intact
* Issue another request to this URL: 'https://wp.dieschoenewolke.com/'
* Connected to wp.dieschoenewolke.com (123.456.789.0) port 443 (#2)
*  subject: CN=wp.dieschoenewolke.com
*  start date: Feb  1 11:55:35 2024 GMT
*  expire date: May  1 11:55:34 2024 GMT
*  subjectAltName: host "wp.dieschoenewolke.com" matched cert's "wp.dieschoenewolke.com"
* using HTTP/2
* h2h3 [:path: /]
* h2h3 [:authority: wp.dieschoenewolke.com]
> GET / HTTP/2
> Host: wp.dieschoenewolke.com
> accept: */*
I run it through docker-compose and when I use the simple reverse_proxy setup without the redir https://dieschoenewolke.com in the 2nd line of my Caddyfile everything runs fine.
Debian GNU/Linux 11 (bullseye)
Client: Docker Engine - Community
Version: 25.0.2
Server: Docker Engine - Community
Engine:
Version: 25.0.2
    redir https://{host}{uri}
www.dieschoenewolke.com:443 {
    redir https://wp.dieschoenewolke.com
wp.dieschoenewolke.com:443 {
	reverse_proxy 192.168.178.2:18000
	tls {$CLOUDFLARE_EMAIL} {
        dns cloudflare {$CLOUDFLARE_API_TOKEN}
Why do you have this line? It’s essentially causing an infinite loop of redirects.
I’m not sure I understand your goal here. Please elaborate.
Thank you for your response Francis!
What I’m trying to achieve is to point wp.dieschoenewolke.com to dieschoenewolke.com without the subdomain in the adress bar.
Okay, then put your reverse_proxy inside dieschoenewolke.com and remove redir from there.
