caddyContainer | 2021/02/02 13:30:36 http: TLS handshake error from 5.121.248.21:49361: read tcp 172.17.0.3:443->5.121.248.21:49361: read: connection timed out
caddyContainer | 2021/02/02 13:30:52 http: TLS handshake error from 5.114.71.141:58459: read tcp 172.17.0.3:443->5.114.71.141:58459: read: connection timed out
caddyContainer | 2021/02/02 13:30:55 http: TLS handshake error from 188.160.212.229:1038: no certificate available for '172.17.0.3'
caddyContainer | 2021/02/02 13:30:59 http: TLS handshake error from 199.30.231.5:44459: no certificate available for 'www.fanimekufxtipo.ml'
caddyContainer | 2021/02/02 13:31:14 http: TLS handshake error from 5.127.232.75:53865: read tcp 172.17.0.3:443->5.127.232.75:53865: read: connection timed out
caddyContainer | 2021/02/02 13:31:21 http: TLS handshake error from 83.120.111.180:54876: no certificate available for 'eyeshirtculture.net'
caddyContainer | 2021/02/02 13:32:20 http: TLS handshake error from 91.99.180.126:2053: read tcp 172.17.0.3:443->91.99.180.126:2053: read: connection timed out
caddyContainer | 2021/02/02 13:32:23 http: TLS handshake error from 168.184.84.226:42877: no certificate available for 'www.mountaininterrobotfront.com'
caddyContainer | 2021/02/02 13:32:25 http: TLS handshake error from 5.112.197.181:13902: read tcp 172.17.0.3:443->5.112.197.181:13902: read: connection timed out
caddyContainer | 2021/02/02 13:32:30 http: TLS handshake error from 46.62.174.4:3576: read tcp 172.17.0.3:443->46.62.174.4:3576: read: connection timed out
caddyContainer | 2021/02/02 13:32:33 http: TLS handshake error from 51.36.4.135:1632: read tcp 172.17.0.3:443->51.36.4.135:1632: read: connection timed out
caddyContainer | 2021/02/02 13:32:35 http: TLS handshake error from 5.208.110.226:47822: no certificate available for 'www.avenueflex.net'
caddyContainer | 2021/02/02 13:32:43 http: TLS handshake error from 151.235.39.95:10056: no certificate available for 'www.duckmonkey.com'
caddyContainer | 2021/02/02 13:32:48 http: TLS handshake error from 195.94.13.10:55294: no certificate available for '172.17.0.3'
caddyContainer | 2021/02/02 13:32:52 http: TLS handshake error from 51.36.13.192:1934: read tcp 172.17.0.3:443->51.36.13.192:1934: read: connection timed out
caddyContainer | 2021/02/02 13:32:54 http: TLS handshake error from 5.114.105.113:37049: read tcp 172.17.0.3:443->5.114.105.113:37049: read: connection timed out
caddyContainer | 2021/02/02 13:33:18 http: TLS handshake error from 2.191.19.29:55944: no certificate available for 'www.shareitspassart.com'
caddyContainer | 2021/02/02 13:33:32 http: TLS handshake error from 5.126.17.105:25912: read tcp 172.17.0.3:443->5.126.17.105:25912: read: connection timed out
caddyContainer | 2021/02/02 13:33:39 http: TLS handshake error from 2.190.223.26:49117: read tcp 172.17.0.3:443->2.190.223.26:49117: read: connection timed out
caddyContainer | 2021/02/02 13:33:39 http: TLS handshake error from 5.160.46.56:35498: read tcp 172.17.0.3:443->5.160.46.56:35498: read: connection timed out
caddyContainer | 2021/02/02 13:33:45 http: TLS handshake error from 5.121.18.58:33051: read tcp 172.17.0.3:443->5.121.18.58:33051: read: connection timed out
caddyContainer | 2021/02/02 13:33:52 http: TLS handshake error from 46.56.245.66:5222: no certificate available for '172.17.0.3'
caddyContainer | 2021/02/02 13:34:04 http: TLS handshake error from 102.87.142.213:35338: read tcp 172.17.0.3:443->102.87.142.213:35338: read: connection timed out
caddyContainer | 2021/02/02 13:34:07 http: TLS handshake error from 41.210.154.233:12409: no certificate available for '172.17.0.3'
caddyContainer | 2021/02/02 13:34:10 http: TLS handshake error from 46.41.197.26:51882: read tcp 172.17.0.3:443->46.41.197.26:51882: read: connection timed out
caddyContainer | 2021/02/02 13:34:21 http: TLS handshake error from 5.122.11.105:47365: read tcp 172.17.0.3:443->5.122.11.105:47365: read: connection timed out
caddyContainer | 2021/02/02 13:34:29 http: TLS handshake error from 154.160.2.59:6744: read tcp 172.17.0.3:443->154.160.2.59:6744: read: connection reset by peer
caddyContainer | 2021/02/02 13:34:35 http: TLS handshake error from 93.117.176.95:65059: no certificate available for 'junctiontownintfusion.com'
The above is a sample from the logs for our caddy container, and there are plenty more similar. We are running caddy using a docker container. None of the ip addresses above, or domains are recognizable to me.
Caddyfile:
subdomain
redir /ui /ui/
handle_path /ui/* {
root * /app/build/
handle_path /* {
reverse_proxy ip:port
handle /env-config.js {
header Content-Type text/javascript
respond `window.config = {"REACT_APP_WEBSOCKET": "{$REACT_APP_WEBSOCKET}", "REACT_APP_REDIRECT": "{$REACT_APP_REDIRECT}"};`
level DEBUG
