Secure Websockets for Janus / WebRTC
I am developing a videostreaming system, using a raspberry pi with a webcam as the source of video. Another computer is serving a Janus WebRTC server (in a docker), using websockets as the means of communication. On the same computer, I have Caddy installed in a separate docket, to act both as a reverse proxy, and as a webserver.
So far I am using the same computer to test, using both localhost and 192.168.1.133 in order to observe how it works. In the future, I plan to move everything to a separate Proxmox box.
I have managed to settle the webserving, including using a domain by duckdns. Before using caddy, everythign worked on localhost with http, but now moving on to https, I resorted to Caddy (as otherwise, webRTC will not work). unfortunately, now I am running in problems, the latest unresolved being that I have to use wss: rather. than ws: as otherwise, it will not work.
However, with secure websockets, I cannot get a connection between the local pc and the Janus server through caddy.
I have tried:
  1. removing port from calling js script
  2. using ws:
  3. using *****.duckdns.org domain, with or without port specified
  4. using a separate port, to redirect from 8189 → 8188
No Caddy logs relevant, including using Debug
From Chrome: janus.js:107 WebSocket connection to ‘wss://192.168.1.133:8188/’ failed:
Caddy v 2.10.0 in Docker.
Docker, from https://hub.docker.com/_/caddy
image: caddy:2.10.0
cap_add:
- NET_ADMIN
- “80:80”
- “443:443”
- “443:443/udp”
- “8123:8123”
- web_data:/usr/share/caddy
- caddy_data:/data
- caddy_config:/config
janus:
image: canyan/janus-gateway:latest
cap_add:
- NET_ADMIN
- “8188:8188”
- janus_config:/usr/local/etc/janus
# debug
format console
http://******.duckdns.org
# log
root * /usr/share/caddy
localhost {
# log
192.168.1.133 {
log
@websockets {
header Connection Upgrade
header Upgrade websocket
reverse_proxy @websockets 192.168.1.133:8188
******.duckdns.org {
log
@websockets {
reverse_proxy 192.168.1.10:8123
Thanks
Assuming you’re accessing your server via
https://YOURSITE.duckdns.org
you could try this:
YOURSITE.duckdns.org {
    log
    @websockets {
    handle @websockets {
        reverse_proxy 192.168.1.133:8188
Then, edit your Janus JavaScript file with this:
var server = "wss://" + window.location.hostname + ":443/";
Let me know if that works. I’m not familiar with Janus and making a lot of assumptions here. Seeing your Janus config would help.
dear timelordx, I do not know what you did, but it is working perfectly :grinning_face:
I hope this all works when I move everything to a new Proxmox server soon. All this was a proof of concept, so at least I know I am on the right track
