): v2.3.0
Ubuntu 20.04 LTS x64
Intel Xeon 2 GHz
Docker version 19.03.8, build afacb8b7f0
docker-compose version 1.26.2, build eefe0d31
Dockerfile to build caddy
FROM caddy:2.3.0-builder AS builder
RUN xcaddy build v2.3.0 \
--with github.com/lucaslorentz/caddy-docker-proxy/plugin/v2@latest \
--with github.com/techknowlogick/caddy-s3browser
FROM caddy:2.3.0
ENTRYPOINT ["/usr/bin/caddy"]
CMD ["docker-proxy"]
export CADDY_DATA_DIR=/var/containerdata/caddy
export CDN_DATA_DIR=/var/containerdata/cdn
export S3_SITENAME="blabla"
export S3_ENDPOINT="localhost:9000"
export S3_REGION="" # optional
export S3_BUCKET=cdn
export S3_PROTO=https
export S3_SECURE=true
export S3_REFRESH=5m
export S3_REFRESH_SECRET="" # A key to protect the refresh api (optional)
export S3_DEBUG=true
export S3_SIGNED_URL_REDIRECT=false
export S3_SORT_ALGORITHM=case-insensitive
docker-compose up -d
version: "3.8"
configs:
caddy-basic-content:
file: ./Caddyfile
labels:
# image: "caddy/caddy:latest"
# image: "lucaslorentz/caddy-docker-proxy:2.3.4-alpine"
image: docker.nexus.mydomain.com:8084/caddy:customcaddy
deploy:
replicas: 1
placement:
constraints: [node.role == manager]
- "/var/run/docker.sock:/var/run/docker.sock:ro"
- "$CADDY_DATA_DIR:/data"
- "$CDN_DATA_DIR:/var/www/cdn"
- my-network
my-network:
external: true
cdn.mydomain.com {
route {
s3browser {
site_name "${S3_SITENAME}" # S3 Browser
endpoint "${S3_ENDPOINT}"
region "${S3_REGION}"
key "${S3_KEY}"
secret "${S3_SECRET}"
secure ${S3_SECURE} # true
bucket "${S3_BUCKET}"
refresh_interval "${S3_REFRESH}" # 5m
refresh_api_secret "${S3_REFRESH_SECRET}"
debug "${S3_DEBUG}" # false
signed_url_redirect ${S3_SIGNED_URL_REDIRECT} # false
sort_algorithm ${S3_SORT_ALGORITHM} # none
s3browser does not seem to work?
[ERROR] Removing invalid block: parsing caddyfile tokens for 'route': Caddyfile:17 - Error during parsing: unrecognized directive: s3browser
cdn.mydomain.com {
route {
s3browser {
site_name ${S3_SITENAME}
endpoint ${S3_ENDPOINT}
region ${S3_REGION}
key ${S3_KEY}
secret ${S3_SECRET}
secure ${S3_SECURE}
bucket ${S3_BUCKET}
refresh_interval ${S3_REFRESH}
refresh_api_secret ${S3_REFRESH_SECRET}
debug ${S3_DEBUG}
I tried to understand if I have to adapt my own Dockerfile based on the s3browser Dockerfile.
Tried different commands but none worked.
What bothers me is that the s3browser’s Dockerfile contains those lines:
RUN \
xcaddy build --with github.com/techknowlogick/caddy-s3browser=/tmp/caddy-s3browser && \
/usr/bin/caddy version && \
/usr/bin/caddy list-modules | grep s3browser &&
and although building with xcaddy works, caddy list-modules
does not contain s3browser
. I assume the maintainer knows what he’s doing, but I don’t understand it.
What is my goal?
I want to serve files from a self-hosted minio (s3 compatible) docker swarm service, to save aws s3 costs. The files should be publicly downloadable, so I need the s3browser
