RussellLuo/caddy-ext/ratelimit
panic: Something in this program imports go4.org/unsafe/assume-no-moving-gc to declare that it assumes a non-moving garbage collector, but your version of go4.org/unsafe/assume-no-moving-gc hasn’t been updated to assert that it’s safe against the go1.19 runtime. If you want to risk it, run with environment variable ASSUME_NO_MOVING_GC_UNSAFE_RISK_IT_WITH=go1.19 set. Notably, if go1.19 adds a moving garbage collector, this program is unsafe to use.
order rate_limit before basicauth
:1501 {
output file A05.log
file_server /resA05/*
route / {
rate_limit * 64r/m
respond 200
:1502 {
reverse_proxy 120.78.166.145:9279
what error is?
