1. Output of caddy version
Raspberry Pi OS 11 through APT and systemD
● caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-11-10 14:21:45 EST; 1min 54s ago
Main PID: 19536 (caddy)
Tasks: 11 (limit: 1830)
CPU: 418ms
└─19536 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.8305492,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"servarr.gappyland.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
Nov 10 14:21:47 deb-rpi-rproxy caddy[19536]: {"level":"error","ts":1668108107.8311334,"logger":"http.acme_client","msg":"challenge failed","identifier":"servarr.gappyland.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:dns","title":"","det>
Nov 10 14:21:47 deb-rpi-rproxy caddy[19536]: {"level":"error","ts":1668108107.83122,"logger":"http.acme_client","msg":"validating authorization","identifier":"servarr.gappyland.com","problem":{"type":"urn:ietf:params:acme:error:dns","title":"","detail":"DNS problem: SE>
Nov 10 14:21:49 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108109.0362806,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"servarr.gappyland.com","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
Nov 10 14:21:50 deb-rpi-rproxy caddy[19536]: {"level":"error","ts":1668108110.396576,"logger":"http.acme_client","msg":"challenge failed","identifier":"servarr.gappyland.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:dns","title":"",">
Nov 10 14:21:50 deb-rpi-rproxy caddy[19536]: {"level":"error","ts":1668108110.396922,"logger":"http.acme_client","msg":"validating authorization","identifier":"servarr.gappyland.com","problem":{"type":"urn:ietf:params:acme:error:dns","title":"","detail":"DNS problem: S>
Nov 10 14:21:50 deb-rpi-rproxy caddy[19536]: {"level":"error","ts":1668108110.3972235,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"servarr.gappyland.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:p>
Nov 10 14:21:50 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108110.40008,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["servarr.gappyland.com"],"ca":"https://acme.zerossl.com/v2/DV90","account":"caddy@zerossl.com"}
Nov 10 14:21:50 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108110.4001958,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["servarr.gappyland.com"],"ca":"https://acme.zerossl.com/v2/DV90","account":"caddy@zerossl.com"}
Nov 10 14:21:52 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108112.25368,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"servarr.gappyland.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Type=notify
gappyland.com {
root * /var/www/html
reverse_proxy /jellyfin/* 192.168.5.50:8096
reverse_proxy /komga* 192.168.5.50:8080
servarr.gappyland.com {
reverse_proxy /radarr* 192.168.5.50:7878
reverse_proxy /sonarr* 192.168.5.50:8989
I am trying to set up a subdomain which runs behind Tailscale, but I am getting “challenge failed” and “SERVFAIL” errors in the logs and the site shows “Error code: SSL_ERROR_INTERNAL_ERROR_ALERT”. I’ve set my Google Domain’s A and AAAA records like this:
gappyland.com - A - Public IPv4
gappyland.com - AAAA - Public IPv6
servarr.gappyland.com - A - Tailscale IPv4
servarr.gappyland.com - AAAA - Tailscale IPv6
So far as I understand, Caddy will request SSL certs for all domains defined in the Caddyfile but I don’t think that is happening properly. I’m not sure if the issue is with the Caddyfile (maybe I need to define a certain TLS option manually?), if it’s because I’m running the subdomain through Tailscale, or if my DNS records are not set up properly.
Nov 10 14:21:45 deb-rpi-rproxy systemd[1]: Starting Caddy...
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: caddy.HomeDir=/var/lib/caddy
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: caddy.Version=v2.6.2 h1:wKoFIxpmOJLGl3QXoo6PNbYvGW4xLEgo32GPBEjWL8o=
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: runtime.GOOS=linux
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: runtime.GOARCH=arm64
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: runtime.Compiler=gc
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: runtime.NumCPU=4
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: runtime.GOMAXPROCS=4
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: runtime.Version=go1.19.2
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: os.Getwd=/
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: LANG=en_GB.UTF-8
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: NOTIFY_SOCKET=/run/systemd/notify
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: HOME=/var/lib/caddy
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: LOGNAME=caddy
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: USER=caddy
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: INVOCATION_ID=7f88f456fa194d238f69729cbeaad19d
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: JOURNAL_STREAM=8:42250
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.267036,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"warn","ts":1668108105.2708948,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":34}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.273863,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.274323,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2743795,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2752733,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x4000700f50"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2760944,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.276328,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2764971,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2766314,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2766514,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["gappyland.com","servarr.gappyland.com"]}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2773557,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2810223,"logger":"tls","msg":"finished cleaning storage units"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2834857,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2841089,"logger":"tls.obtain","msg":"acquiring lock","identifier":"servarr.gappyland.com"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2847242,"msg":"serving initial configuration"}
Nov 10 14:21:45 deb-rpi-rproxy systemd[1]: Started Caddy.
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2990992,"logger":"tls.obtain","msg":"lock acquired","identifier":"servarr.gappyland.com"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.2996101,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"servarr.gappyland.com"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.3021734,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["servarr.gappyland.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
Nov 10 14:21:45 deb-rpi-rproxy caddy[19536]: {"level":"info","ts":1668108105.3022444,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["servarr.gappyland.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
Nov 10 14:21:47 deb-rpi-rproxy caddy[19536]: {"level":"error","ts":1668108107.8311334,"logger":"http.acme_client","msg":"challenge failed","identifier":"servarr.gappyland.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:dns","title":"","detail":"DNS problem: SERVFAIL looking up A for servarr.gappyland.com - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for servarr.gappyland.com - the domain's nameservers may be malfunctioning","instance":"","subproblems":[]}}
Nov 10 14:21:47 deb-rpi-rproxy caddy[19536]: {"level":"error","ts":1668108107.83122,"logger":"http.acme_client","msg":"validating authorization","identifier":"servarr.gappyland.com","problem":{"type":"urn:ietf:params:acme:error:dns","title":"","detail":"DNS problem: SERVFAIL looking up A for servarr.gappyland.com - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for servarr.gappyland.com - the domain's nameservers may be malfunctioning","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/818117387/142816853477","attempt":1,"max_attempts":3}
I set up my base domain on the Tailscale IP and it functioned as expect, my issue is only setting it up on a subdomain.
None
