Hi,
I’m trying to run selfoss with caddy and as selfoss wasn’t designed to work with it, it only provides a .htaccess. I tried to convert it myself but it hasn’t been a successful enterprise. Therefore I’m turning to this forum for help converting it.
# Enable rewrite engine and route requests to framework
RewriteEngine On
#RewriteBase /selfoss
# rule for ACME
RewriteRule .well-known/(.*) - [L]
# rule for favicons
RewriteRule !data/favicons/(.*)$ - [C]
RewriteRule favicons/(.*)$ data/favicons/$1 [L]
# rule for thumbnails
RewriteRule !data/thumbnails/(.*)$ - [C]
RewriteRule thumbnails/(.*)$ data/thumbnails/$1 [L]
# rule for front controller
RewriteCond %{QUERY_STRING} ^(.*)$
RewriteRule !.(js|ico|gif|jpg|png|css|asc|txt|eot|woff|ttf|ttf|svg|xml)$ index.php?%1
# rule for files
RewriteRule !favicons/ - [C]
RewriteRule !thumbnails - [C]
RewriteRule !public - [C]
RewriteRule !index.php - [C]
RewriteRule (.*) public/$1 [L]
# set magic_quotes_gpc as f3 wouldn't start otherwise
<IfModule mod_php5.c>
php_value magic_quotes_gpc "1"
</IfModule>
# deny requests for config files
<FilesMatch ".(ini)$">
Order allow,deny
Deny from all
</FilesMatch>
# Disable ETags
<IfModule mod_headers.c>
Header Unset ETag
FileETag none
</IfModule>
# Default expires header if none specified (stay in browser cache for 7 days)
<IfModule mod_expires.c>
ExpiresActive on
ExpiresDefault "access plus 1 week"
# CSS
ExpiresByType text/css "access plus 1 year"
# Data interchange
ExpiresByType application/json "access plus 0 seconds"
ExpiresByType application/xml "access plus 0 seconds"
ExpiresByType text/xml "access plus 0 seconds"
# Favicon (cannot be renamed!)
ExpiresByType image/x-icon "access plus 1 week"
# HTML components (HTCs)
ExpiresByType text/x-component "access plus 1 month"
# HTML
ExpiresByType text/html "access plus 0 seconds"
# JavaScript
ExpiresByType application/javascript "access plus 1 year"
# Manifest files
ExpiresByType application/x-web-app-manifest+json "access plus 0 seconds"
ExpiresByType text/cache-manifest "access plus 0 seconds"
# Media
ExpiresByType audio/ogg "access plus 1 month"
ExpiresByType image/gif "access plus 1 month"
ExpiresByType image/jpeg "access plus 1 month"
ExpiresByType image/png "access plus 1 month"
ExpiresByType video/mp4 "access plus 1 month"
ExpiresByType video/ogg "access plus 1 month"
ExpiresByType video/webm "access plus 1 month"
# Web feeds
ExpiresByType application/atom+xml "access plus 1 hour"
ExpiresByType application/rss+xml "access plus 1 hour"
# Web fonts
ExpiresByType application/font-woff "access plus 1 month"
ExpiresByType application/vnd.ms-fontobject "access plus 1 month"
ExpiresByType application/x-font-ttf "access plus 1 month"
ExpiresByType font/opentype "access plus 1 month"
ExpiresByType image/svg+xml "access plus 1 month"
</IfModule>
<IfModule mod_deflate.c>
# Force compression for mangled headers.
# http://developer.yahoo.com/blogs/ydn/posts/2010/12/pushing-beyond-gzipping
<IfModule mod_setenvif.c>
SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)+|[X~-]{4,13}$ HAVE_Accept-Encoding
RequestHeader append Accept-Encoding "gzip,deflate" env=HAVE_Accept-Encoding
</IfModule>
</IfModule>
# Compress all output labeled with one of the following MIME-types
# (for Apache versions below 2.3.7, you don't need to enable `mod_filter`
# and can remove the `<IfModule mod_filter.c>` and `</IfModule>` lines
# as `AddOutputFilterByType` is still in the core directives).
AddOutputFilterByType DEFLATE application/atom+xml \
application/javascript \
application/json \
application/rss+xml \
application/vnd.ms-fontobject \
application/x-font-ttf \
application/x-web-app-manifest+json \
application/xhtml+xml \
application/xml \
font/opentype \
image/svg+xml \
image/x-icon \
text/css \
text/html \
text/plain \
text/x-component \
text/xml
</IfModule>
</IfModule>
# add font types for chromium/chrome
AddType application/font-woff woff
I’m not even sure how much of this is actually pertinent to caddy and what really needs to be converted. I’d be thankful for any help I can get.
