I am playing around with this web application Grocy (https://github.com/grocy/grocy) and currently trying to get it to work with Caddy.
I have a clean install of Manjaro Linux running in a VM and I have run the following commands to setup everything so far:
sudo pacman -Syu --noconfirm yay wget unzip
yay -Syu --noconfirm caddy sqlite php php-fpm php-sqlite
sudo sed -i 's/;extension=pdo_sqlite/extension=pdo_sqlite/g' /etc/php/php.ini
sudo sed -i 's/;extension=sqlite3/extension=sqlite3/g' /etc/php/php.ini
sudo systemctl start php-fpm
sudo systemctl enable php-fpm
sudo systemctl status php-fpm
wget -O grocy_latest.zip https://releases.grocy.info/latest
sudo unzip grocy_latest.zip -d /usr/share/grocy
sudo rm grocy_latest.zip
sudo cp /usr/share/grocy/config-dist.php /usr/share/grocy/data/config.php
sudo chown http:http /usr/share/grocy/data -R
Below is my caddyfile so far:
:9283 {
gzip
errors /var/log/caddy/grocy_error.log
root /usr/share/grocy/public
fastcgi / unix:/run/php-fpm/php-fpm.sock php {
index index.php
rewrite {
r .*
ext /
to /index.php?{query}
This seem to work just fine with the default Grocy data/config.php file. Although any suggestion on how to improve it would be appreciated.
however, I would like to change the base url to /grocy so it will work with my existing reverse proxy. In the Grocy data/config.php file I have changed
Setting(‘BASE_URL’, ‘/’);
to
Setting(‘BASE_URL’, ‘/grocy’);
And restated caddy. This however did not work. Now when I go to http://ipaddress:9293/grocy I get
“Page Not Found”. Do I also have to make changes to the Caddyfile to make this work? Or there something else going on I am not understanding?
Thank you
