1. Caddy version (v2.0.0 h1:pQSaIJGFluFvu8KDGDODV8u4/QRED/OPyIR+MWYYse8=
I am running Caddy in a virtual machine on Ubuntu following the documentation laid out in the download guide.
Ubuntu 20.04 LTS
No commands.
# domain name.
:80
root * /usr/share/caddy
# php_fastcgi localhost:9000
I am running Caddy inside of a virtual machine (I can access using 192.168.64.54) and I would like to enable the API to handle traffic on that IP address so I can use it from my host machine (macOS) and not have to ssh into the virtual machine and use localhost:2019.
No errors.
Read the documentation but did not see how to configure the Caddy API to listen on a different address.
