Running as systemd not enough permissions to create logs
I installed Caddy as described in the documentation for Debian/RaspbianOS
All went fine without errors.
But when I check the service with systemctl status caddy it shows as running and all is green, but it gives the following errors in the bottom
If I stop the service and run caddy manually with sudo caddy run from the dir where the caddyfile is (etc/caddy/caddyfile) then it just runs as expected.
Removing the log part of the caddyfile and caddy runs without errors.
Should caddy not be able to create files and directories by default?
What permissions should the user and group called caddy have?
write error: can't make directories for new logfile: mkdir logs: permission denied
Install — Caddy Documentation.
follow the documentation to the letter
Raspberry Pi 5
RaspbianOS/Debian 12
	# General Options
	log default {
		output file logs/system.log
		format json
		level debug
	admin :2019
	# TLS Options
	email hostmaster@guldager.one
	# Server Options
xn--lovliggr-c5a.nu, www.xn--lovliggr-c5a.nu {
	reverse_proxy 10.0.0.3
		output file logs/lovligdk.access.log
		format json {
			time_local
xn--lovliggr-c5a.dk, www.xn--lovliggr-c5a.dk {
		output file logs/lovlig-dk.access.log
		format json {
			time_local
lovliggoer.nu, www.lovliggoer.nu {
		output file logs/lovlig2.access.log
		format json {
			time_local
You configured the log path to a relative path
Systemd services default to the root / when the WorkingDirectory is not specified. Change it to something more sensible, e.g. /var/logs/caddy or something, and ensure the caddy user has access to the directory either by group or direct user ACL.
Ohh you’r right.
I’m moving caddy from windows to linux, and forgot I could not use the same path.
Thank you for your help
