Hi, is it possible to run caddy together with nginx on the same machine? I would use caddy just for reverse proxy on specific domains, not on ports 80 and 443
Yes it’s possible to run Caddy on different ports, but Caddy needs to be accessible on ports 80 and 443 for Automatic HTTPS to work, because those ports are where ACME issuers attempt to reach Caddy to solve the ACME challenges to prove that you control the server.
Please fill out the help topic template. It’s important to save time for both you and us, because it asks all the typical questions so we can avoid making assumptions when answering questions.
