I want to rewrite an URL who contain http query to another URL who replace the query by a directory.
I have a URL like this:
/main/view/servers.php?server_digest=$1
and I want to rewrite it to /main/view/servers/server_digest
. I tried this:
1 - rewrite /main/view/servers/* /main/view/servers.php?server_digest=$1
2 - rewrite /main/view/servers/(.) /main/view/servers.php?server_digest=$1
3 - rewrite /main/view/servers/(.) /main/view/servers.php?server_digest={query}
I have the same problem with others path
mars 23 16:23:24 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679585004.800531,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
mars 23 16:23:24 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679585004.8013365,"logger":"tls","msg":"finished cleaning storage units"}
mars 23 17:08:15 dedicated-server-05 systemd[1]: Stopping Caddy...
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.005596,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"warn","ts":1679587695.0056965,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.0058038,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0004fd3b0"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.0058901,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.0058987,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
mars 23 17:08:15 dedicated-server-05 systemd[1]: caddy.service: Succeeded.
mars 23 17:08:15 dedicated-server-05 systemd[1]: Stopped Caddy.
mars 23 17:08:15 dedicated-server-05 systemd[1]: caddy.service: Consumed 21.450s CPU time.
mars 23 17:08:15 dedicated-server-05 systemd[1]: Starting Caddy...
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.HomeDir=/var/lib/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.Version=v2.6.4 h1:2hwYqiRwk1tf3VruhMpLcYTg+11fCdr8S3jhNAdnPy8=
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.GOOS=linux
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.GOARCH=amd64
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.Compiler=gc
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.NumCPU=4
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.GOMAXPROCS=4
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.Version=go1.20
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: os.Getwd=/
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: LANG=fr_FR.UTF-8
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: NOTIFY_SOCKET=/run/systemd/notify
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: HOME=/var/lib/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: LOGNAME=caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: USER=caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: INVOCATION_ID=aa5207771d544422a3ef36f39b0ce784
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: JOURNAL_STREAM=8:804662657
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.040275,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"warn","ts":1679587695.044272,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.046815,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0472965,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000446d20"}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0528343,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0529838,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0530102,"logger":"tls","msg":"finished cleaning storage units"}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0530236,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
mars 23 17:08:15 dedicated-server-05 systemd[1]: Started Caddy.
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0542378,"msg":"serving initial configuration"}
(END)
No error appears in the logs.
official installation methods found at Install — Caddy Documentation.
Debian 11 (bullseye) x86_64
systemctl start caddy
:1080 {
header / Cache-Control "no-cache, no-store, must-revalidate"
root * /usr/share/nginx/dark-utilities.com
#tls /etc/nginx/ssl/dark-utilities.com.pem /etc/nginx/ssl/dark-utilities.com.key {
# protocols tls1.3
php_fastcgi unix//run/php/php8.1-fpm.sock
rewrite / /main.html
rewrite /referral/* /referral.html?referral=$1
rewrite /recovery /recovery.php
rewrite /abuse /abuse.html
rewrite /privacy /privacy.html
rewrite /terms /terms.html
rewrite /main/manager /main/manager.php
rewrite /main/premium /main/premium.php
rewrite /main/api-access /main/api-access.php
rewrite /main/rules /main/rules.php
rewrite /main/referral /main/referral.php
rewrite /main/post-exploitation /main/post-exploitation.php
rewrite /main/tickets /main/tickets.php
rewrite /main/documentation /main/documentation.php
rewrite /main/advertisement /main/advertisement.php
rewrite /main/admin/tickets /main/admin/tickets.php
rewrite /main/admin/members /main/admin/members.php
rewrite /main/admin/referral /main/admin/referral.php
rewrite /main/admin/settings /main/admin/settings.php
rewrite /main/view/tickets/* /main/view/tickets.php?ticket_uid=$1
rewrite /api/v1/api-access /api/v1/api-access.php
rewrite /api/v1/report /api/v1/report.php
rewrite /api/v1/nodes-status /api/v1/nodes-status.php
rewrite /api/v1/miners-status /api/v1/miners-status.php
rewrite /api/v1/builds /api/v1/builds.php
rewrite /api/v1/science /api/v1/science.php
rewrite /api/v1/servers/evaluate/* /api/v1/servers-folder/evaluate.php?server_digest=$1
rewrite /api/v1/servers/give/* /api/v1/servers-folder/give.php?server_digest=$1
rewrite /api/v1/servers/shell-stdout/* /api/v1/servers-folder/shell-stdout.php?server_digest=$1
rewrite /api/v1/servers/* /api/v1/servers.php?server_digest=$1
rewrite /api/v1/servers /api/v1/servers.php
rewrite /api/v1/webhooks/* /api/v1/webhooks.php?query=$1
rewrite /api/v1/manager/attacks /api/v1/manager-folder/attacks.php
rewrite /api/v1/manager /api/v1/manager.php
rewrite /api/v1/tickets/reply/* /api/v1/tickets-folder/reply.php?ticket_uid=$1
rewrite /api/v1/tickets/* /api/v1/tickets.php?ticket_uid=$1
rewrite /api/v1/tickets /api/v1/tickets.php
rewrite /api/v1/admin/tickets /api/v1/admin/tickets.php
rewrite /api/v1/admin/members/* /api/v1/admin/members.php?user=$1
rewrite /api/v1/admin/members /api/v1/admin/members.php
rewrite /api/v1/admin/referral /api/v1/admin/referral.php
rewrite /api/v1/users/wallet /api/v1/users-folder/wallet.php
rewrite /api/v1/users/two-factor /api/v1/users-folder/two-factor.php
rewrite /api/v1/users/api /api/v1/users-folder/api.php
rewrite /api/v1/auth/two-factor /api/v1/auth/two-factor.php
rewrite /api/v1/referral /api/v1/referral.php
rewrite /api/v1/@me /api/v1/@me.php
rewrite /api/v1/premium /api/v1/premium.php
rewrite /api/v1/ssh-auto-link /api/v1/ssh-auto-link.php
rewrite /api/v1/vector-map /api/v1/vector-map.php
rewrite /api/v1/notifications /api/v1/notifications.php
route /auth/login {
try_files {path} /auth/login.php?{query}
route /auth/logout {
try_files {path} /auth/logout.php
route /auth/two-factor {
try_files {path} /auth/two-factor.php
route /main/vendor/* {
rewrite * /error_files/401.html
header Content-Type text/html
handle_errors {
@404 expression {http.error.status_code} == 404
@401 expression {http.error.status_code} == 401
route @401 {
route @404 {
rewrite * /error_files/404.html
