Rewrite without middle part
Hi,
Im getting 404 errors on requests for .js and .css files
/assets/js/main.1704061619.js
should redirect to
/assets/js/main.js
Can’t figure out the way get the filename without the version part.
here’s my Caddyfile
root ./public
log ./caddy.log
errors ./caddy-error.log
tls off
fastcgi / 127.0.0.1:9000 php {
	index index.php
rewrite {
	to {path} {path}/ /index.php?{query}
rewrite {
	if_op or
	if {file} ends_with .css
	if {file} ends_with .js
    to ...
Something like the following untested rewrite would probably work:
rewrite {
  if_op or
  r ^\/assets\/(js|css)\/main\.\d+\.(js|css)$
  to /assets/{1}/main.{2}
thanks, sorry my example wasn’t clear enough. I needed a regex to match the filename regardless of the path
This is what I ended up doing
rewrite {
    r  ^(.+)\.([\d\_]+)\.(js|css|png|jpg|gif)$
    to /{1}.{3}
