in nginx this is possible:
location /robots.txt {return 200 “User-agent: *\nDisallow: /\n”;}
In my proxies I would like to map requests for robots.txt to either the solution above or a robots.txt file somwhere on my caddy server, using the same file for all proxies.
Thanks, John
abiosoft
(Abiola Ibrahim)
September 3, 2016, 4:11pm
#2
Try this. Note that you need to build from source or wait for 0.9.2 to use status .
header /robots.txt {
User-agent *
Disallow /
status 200 /robots.txt
Hello,
Thank you very much for your answer!
Kind Regards, John
I did solve it with writing the X-Robots-Tag for all requests instead.
But it would be nice to be able to write a response body with the status command, is this something you plan to do? If not, do think it’s a bad idea?
Kind Regards
system
(system)
closed
December 24, 2016, 11:53am
#5
