Hello,
I am using caddy in a small production server. So far everything runs fine, however, I’d like to add a rewrite rule to try the URL with and without trailing slash.
I am not sure if the overall construction is correct, especially the rewrite rule,
rewrite {
regexp ^(.+)/$
to {1} {1}/ /404/
Should I use ^(.+)/$ or ^(.+)/?$ (added question mark for making optional the trailing slash in the regex)?
For completeness, I have attached below the main part of the configuration.
Thank you,
Jose
\# Locale detection
locale en es {
detect cookie header
\# Home redirection
redir {
if {path} is /
/ /{>Detected-Locale}/ 302
\# Try in order: no_slash, with_slash, 404
rewrite {
regexp ^(.+)/$
to {1} {1}/ /404/
\# Permanent redirection no_slash to with_slash
redir 301 {
if {uri} not_ends_with /
if {rewrite_uri} ends_with /
/ {rewrite_uri}
\# 404 Not Found
redir {
if {rewrite_uri} is /404/
/ /{>Detected-Locale}/404.html 301
\# https://www.fastly.com/blog/best-practices-using-vary-header
header / Vary "Cookie, Accept-Language, Vary: Accept-Encoding"
\# Expires: 7 days
expires {
match (.css|.js|.jpg|.png)$ 7d
