All pages are indexed based on query parameters. I am lunching a new site and I want to 301 redirect all indexed pages to search engine friendly urls.
This is my Caddyfile testing it locally:
localhost:8080
gzip
log access.log
rewrite /index.php {
if {query} match view=frontpage
to /test
if {query} match view=demo
to /demo
Rewrite works but query parameters are appended to the URL after rewrite. My URL looks like this /test/?option=com_content&view=frontpage&Itemid=1
Is there a way to rewrite without the queries ?
I also tried using redir like this:
redir 301 {
/index.php /test
redir 301 {
/index.php /demo
Redir does not include the query parameters if it is just one redirect, but I get an error Error during parsing: rule with duplicate 'from' value: /index.php -> /test.
Yeah, I thought there was an open issue about this but I can’t find it now. This is on my TODO list; redirects shouldn’t be duplicates if they have if statements, even if the path is the same.
rewrite {
if {query} has view=frontpage # use substring 'has' instead of regex 'match'; faster
to /redir-to-test/
redir 301 {
if {rewrite_uri} is /redir-to-test/
/redir-to-test/ /test
rewrite {
if {query} has view=demo
to /redir-to-demo/
redir 301 {
if {rewrite_uri} is /redir-to-demo/
/redir-to-demo/ /demo
Thanks! Messy or not I will use it.
I have to redirect around 30 pages like this. Do you think it can cause any other drawbacks (slower server response or something else) beside the messy part?
Nah, should be pretty quick - I’d bet (not based on any actual benchmarks, mind) that 100s of these probably won’t have a big impact (unless you’re using match instead of has).
This part did not work for some reason if {rewrite_uri} is /redir-to-demo/. The rewrite worked but then it did not redir.
What I tried was this:
rewrite {
to /redir-to-demo/
redir 301 {
rewrite {
if {query} has view=test
to /redir-to-test/
redir 301 {
It worked. I am not very good with servers and I really can’t give you good explanation why if {rewrite_uri} is /redir-to-demo/ did not work. It seems a better solution.
