I’ve edited your post to format the Caddyfile content in code blocks for readability.
Do you have Caddy log lines from when this rewrite fails to operate as expected?
I believe this is expected behaviour as rewrite operates before header does - you’ll need to add the header to the URI you’re rewriting to, not the one you’re rewriting from.
The log line shows the following when using rewrite /foo (or rewrite /foo/) HTTP/2.0 Request: GET 0t.b5z.net/foo/111/i/u/424807/i/choppers_apparel.jpg /foo/111/i/u/424807/i/choppers_apparel.jpg 404
when using rewrite / it is: HTTP/2.0 Request: GET 0t.b5z.net/zirw/111/i/u/424807/i/choppers_apparel.jpg /i/u/424807/i/choppers_apparel.jpg 200
On the header, I need to have the header added only when /foo is present in the url. Is there a way I can do that?
Also something else I noticed but haven’t setup a test scenario for is that within the proxy directive with an except setting it wouldn’t proxy requests I thought it should be proxying. the following excerpt from caddyfile
Consider using a path scoped site label. You shouldn’t even need a rewrite in this case. I also used the opportunity to test your proxy except issue, and demonstrate applying the header for requests starting /foo. The example Caddyfile:
whitestrake at apollo in ~/Projects/test
❯ curl -IL localhost:2015/foo/111/index.txt
HTTP/1.1 301 Moved Permanently
Content-Type: text/html; charset=utf-8
Expires: Sun, 09 Sep 2026 05:00:00 GMT
Server: Caddy
Date: Thu, 05 Apr 2018 23:48:38 GMT
HTTP/1.1 200 OK
Accept-Ranges: bytes
Content-Length: 14
Etag: "p6qkoae"
Last-Modified: Thu, 05 Apr 2018 23:45:46 GMT
Server: Caddy
❯ curl -IL localhost:2015/inc
HTTP/1.1 404 Not Found
Server: Caddy
X-Content-Type-Options: nosniff
Date: Thu, 05 Apr 2018 23:48:39 GMT
Content-Length: 14
HTTP/1.1 200 OK
Date: Thu, 05 Apr 2018 23:48:41 GMT
Server: Caddy
Server: Caddy
The log output:
HTTP/1.1 Request: HEAD /foo/111/index.txt /111/index.txt
HTTP/1.1 Request: HEAD /foo/111/ /111/
HTTP/1.1 Request: /inc -
HTTP/1.1 Request: / http://localhost:2016
The issue with the proxy is that the exception /i/ is saved, but during the comparison, the result of a path.Clean is what’s actually checked against, which removes the trailing slash; effectively, except /i/ is the same as except /i.
thanks I’ll definitely try that. the except issue, is that a bug since it seems counter intuitive and I think it happens with a lot of the config settings?
I agree. It gets a bit complicated, I think, because the path.Clean is very useful in ensuring the result of the path.Join is valid. Perhaps some extra checking could be done for a trailing slash, to be re-added to the result if necessary prior to the comparison.
