Wayne
(SC)
March 27, 2021, 11:50am
#1
reverse_proxy https://target-server:443 {
keepalive 300s
Scenario:
Client --[http:80]–> Caddy ReverseProxy --[https:443]–> Target Server
The Target Server absolutely requires SSL Session Reuse.
Is this possible with Caddy? How would the Caddyfile be?
Any help appreciated
Could you please fill out the rest of the help topic template?
What problem are you actually seeing? Is there an error being presented from your backend? How do you know it’s not already working as expected?
Wayne
(SC)
March 27, 2021, 3:05pm
#3
Hello francislavoie
When I check the logs on the target server, I see that there are different SSL Session IDs.
I don’t think filling out the rest of the template will help because I guess it is more a generic question, if Caddy is capable of SSL session reuse when acting as a reverse proxy or not.
system
(system)
closed
April 26, 2021, 11:51am
#4
