Hi! I want to reverse_proxy the traffic with their http headers intact. The documentation says:
By default, Caddy passes thru incoming headers to the backend—including the
Host
header—without modifications, with two exceptions:
- It adds or augments the X-Forwarded-For header field.
- It sets the X-Forwarded-Proto header field.
I don’t want this default. Basically I don’t want to change any headers. How to do it?
v2.4.3
ubuntu 18.04
systemctl start caddy
reverse_proxy localhost:9000
X-Forwarded-For and X-Forwarded-Proto headers are changed.
Want: no header changes.
