Reverse_proxy with port and path
Hello.
I have two webapps (SafeQ 6) running on Tomcat 9 in my LAN:
  1. print.kstk.lan
  2. print.kstk.lan:9090/end-user/ui/login
When I use reverse_proxy in my Caddyfile for the first one:
print.kostka-skola.cz {
reverse_proxy print.kstk.lan
everything is OK and I have my webapp on https://print.kostka-skola.cz Its wonderful!
What do I have to do for the second one? Configuration in Caddyfile like this is not working
mprint.kostka-skola.cz {
reverse_proxy print.kstk.lan:9090/end-user/ui/login
Caddy v2.8.4
Ubuntu Server
I think for tomcat if the app has a specific virtual directoy as base path you can do this:
app1.example.com {
		rewrite * /end-user/ui/login{uri}
		reverse_proxy tomcat.example.com:8080
This will prepend the path to all requests. Or so Ive heard from a tomcat user I had to do with before. Feel free to correct me if this is wrong.
Thank you for your answer. When I use in my Caddyfile
it generate address mprint.kostka-skola.cz/end-user/ui/login and I get an error: ERR_TOO_MANY_REDIRECTS
Where’s it redirecting to?
It might need some different/special handling depending on how it works.
Try enabling the debug global option, running curl -vL on your site, and posting the output of both.
