1. Output of caddy version
$ caddy version
sudo caddy run # via a Caddyfile
$ uname -a
Linux outserv-zero 5.15.0-53-generic #59-Ubuntu SMP Mon Oct 17 18:53:30 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.1 LTS
Release: 22.04
Codename: jammy
Paste command here.
Paste your config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I want to have two upstreams for my reverse proxy. The issue is, one of them has a path, and the other doesn’t. Like upstream1.com and upstream2.com/path/subpath . Also, one of them is HTTP, and the other is HTTPS.
All the comms are done via POST requests. So, requests don’t have paths. The reason upstream 2 uses a path is as an API key. Is there a way to load balance across these upstreams via Caddy?
