Essentially I’ve been using this template: GitHub - TomDoesTech/caddy-nodejs-docker-tutorial in an attempt to to try deploy a golang application with automatic tls. It all works fine for the most part and I can call GET endpoints on my app through the https url however when I try and call a POST endpoint the golang application sees that it insteads gets a GET request instead. This is not the case when testing on localhost. I’m new to caddy and this kind of technology so I’m assuming I’ve done something wrong on my end.
Inside a docker compose file
image: caddy/caddy:2.6.4-alpine
container_name: caddy-service
- “80:80”
- “443:443”
- ./site:/srv
- caddy_data:/data
- caddy_config:/config
Docker
version: '3.7'
server:
container_name: server
build:
context: ./
# Run the caddy server
- ./site:/srv
- caddy_data:/data
caddy_data:
caddy_config:
api.Idontknowman.xyz {
reverse_proxy server:4000
