Caddy Version: 2 + Cloudflare Plugin
Docker
docker-compose up -d
version: "3.7"
build: .
CLOUDFLARE_EMAIL:
CLOUDFLARE_API_TOKEN:
- "4443:443/tcp"
- ./caddyfile:/etc/caddy/Caddyfile
email {env.CLOUDFLARE_EMAIL}
acme_dns cloudflare {env.CLOUDFLARE_API_TOKEN}
auto_https disable_redirects
https_port 443
sub.domain.country {
reverse_proxy http://192.168.1.2:1005
handle_errors {
respond "{http.error.status_code} Service unavailable."
reverse_proxy https://192.168.1.2:1006 {
tls_insecure_skip_verify
Hello guys,
I have a question. I have a lot of reverse proxy entries. Something I would like is to provide a webpage or at least a message if a reverse proxy origin is unavailable.
As described at the next topic, the supposed solution did not work.
I went searching and found handle_errors assuming that unavailability would provide an error code.
