1. Output of caddy version
v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
Windows 2012
Microsoft Windows [Version 6.2.9200]
caddy_windows_amd64.exe run
n.a.
# auto_https disable_redirects
webmail.gezondheidscentrumdesprank.nl {
reverse_proxy 127.0.0.1:8443
www.fysiotherapiedemortel.nl {
handle_path /webmail/* {
redir https://webmail.fysiotherapiedemortel.nl
redir /webmail /webmail/
reverse_proxy 127.0.0.1:81
www.gezondheidscentrumdesprank.nl {
redir https://webmail.gezondheidscentrumdesprank.nl
ftp.gezondheidscentrumdesprank.nl,
ftp.fysiotherapiedemortel.nl,
secu.fysiotherapiedemortel.nl,
vpn.fysiotherapiedemortel.nl,
xibo.fysiotherapiedemortel.nl {
dev.fysiotherapiedemortel.nl,
dev.gezondheidscentrumdesprank.nl {
reverse_proxy 127.0.0.1:18081
I would like to reverse proxy two domains to underlying servers on the same machine that is hosting caddy (i.e. apache 81 on , IIS on 18081 and kerio mailserver on 8443).
So webmail.[domain].nl needs to be proxied to 8443. dev.[domain].nl needs to be proxied to 18081, and all other subdomains need to be proxied to 81.
This part I can get working with the reverse_proxy directive.
What I furthermore would like to achieve is that when I enter www.[domain].nl/webmail, I get redirected to webmail.[domain].nl.
This seems to be working to.
And lastly, the parts which I can’t get to work, is that kerio hosts it’s file on a path /webmail. However I would lik to rewrite this to /. So that when accessing the webmail, one navigates to webmail.[domain].nl instead of webmail.[domain].nl/webmail/
And of course, all http request should be redirected to https.
Note, the underlying server all transport of non-secure port, but these do rely on the subdomain referer…
n.a.
